Why is it so hard just to ask plusnet a question
- Why is it so hard just to ask plusnet a question
24-09-2007 9:40 PM
Re: Why is it so hard just to ask plusnet a question
24-09-2007 9:50 PM
Signon-on,
Connection settings,
Control your broadband,
Change IP settings
ought to do it.
You might be asked to justify your request though.
24-09-2007 9:52 PM
24-09-2007 9:53 PM
You won't be asked to justify your request, it's done automagically but for the change to take effect, you need to disconnect and then re-connect.
Regards .....
24-09-2007 9:58 PM
(Direct link to where axisofevil directed you - if you're not logged in to the Portal you'll need to enter your user name and password after clicking on the link)
24-09-2007 10:46 PM
Apparently, Plusnet will give you a block of up to 4 static addresses - if you can justify it.
Question:-
For the purposes of email is this a dynamic static IP address or a static static IP address?
24-09-2007 10:52 PM
There is a RIPE request form on the usertools site for requesting them here
25-09-2007 9:23 AM
25-09-2007 12:31 PM
Quote from: lespearson snip.. I dont want to read assistant......ALL I WANNA DO IS REQUEST A STATIC IP ADDRESS..
If you did want to read up on how our Static IP addresses work and how you might apply for a block of IPs, the Help Assistant has a load of useful information linked from its 'Technical Support' section (click 'more' under that category).
There's a section where you can raise a specific question to our support team if you can't find the answer you are looking for in our online help docs: 'Ask a Question about IP addresses'. As Chris has said, some products do not have a Static IP address available as an option. The support page will tell you more;
http://portal.plus.net/support/broadband/products/faqs_and_guides/IP_addresses_broadband.shtml#1
25-09-2007 2:55 PM
25-09-2007 7:17 PM
Quote For the purposes of email is this a dynamic static IP address or a static static IP address?
All the IP addresses they give out are dynamic.
25-09-2007 7:50 PM
Would I need to purchase a domain with a true static address to defeat the DNS lookup feature?
25-09-2007 8:49 PM
As the previous poster said Plusnet have white listed them although other ISP's wont have.
25-09-2007 11:25 PM
Quote from: astarsolutions
I think this would be clearer if you called them fixed dynamic IP addresses - fixed because for all except BB+ you are allocated a fixed IP address, dynamic because the fixed IP address you are given is taken out of a range of IP numbers which are classed as dynamic.
Quote from: axisofevil So if I send email to someone who uses the recently defunct PlusNet DNS lookup feature, would it get rejected?
No - your mail client should be configured to send mail out via relay.plus.net. This complies with all the rules and mail sent in that manner should be accepted by any ISP or business.
Where people will run in to trouble is if they are running their own server and instead of configuring it to relay via Plusnet's relay.plus.net configure it to send direct. Then other ISPs and businesses should reject the mail. I speak from bitter experience when I first set up a mail server in the office in which I then worked.
26-09-2007 12:44 PM
