Why is a "degraded" line not a faulty line?
- Why is a "degraded" line not a faulty line?
Re: Why is a "degraded" line not a faulty line?
27-11-2012 4:15 PM
27-11-2012 4:33 PM
Quote from: JohnJ As he was getting a 5Mbps signal at the cabinet, he thinks that the most likely cause is between the cabinet and the pole and ...
How far away from your house is the cabinet?
What attenuation values did his equipment show between readings at the cabinet and your master socket? And at the DP?
3Mb FTTC
27-11-2012 4:57 PM
I know that the attenuation reading at my master socket was about 52dB, as it was the same as my router, and I was present to ask.
However, I don't know the attenuation readings anywhere else, but he may have included that in the notes to Plusnet.
28-11-2012 6:29 PM
I noticed that happening and took the opportunity to grab some statistics while at a few stages.
14:15 14:35 14:37 15:07 17:11
DOWNSTREAM (Rx)
Noise Margin: 9.3 dB 9.1 dB 9.3 dB 9.2 dB 8.5 dB
Connection Rate: 3833 Kbps 3833 Kbps 3769 Kbps 3769 Kbps 3769 Kbps
Line Attenuation: 52.5 dB 52.5 dB 53.0 dB 53.0 dB 53.0 dB
Power: 0.0 dBm 0.0 dBm 0.0 dBm 0.0 dBm 0.0 dBm
Max Rate: 4800 Kbps 4780 Kbps 4256 Kbps 4692 Kbps 4488 Kbps
SuperFrames: 29950 100539 3479 108566 573411
SF (CRC) Errors: 0 0 0 0 2326
Reed Solomon: 1946766 6535076 226174 7056844 37271748
RS Corrected: 1357 1604 32 937 138817
RS Un-Corrected: 0 0 0 0 34233
HEC: 0 0 0 0 2311
Errored Seconds: 161741 161741 161751 161751 161799
Severe ES: 153311 153311 153320 153320 153358
Interleave Depth: 32 32 32 32 32
Bitswaps: 62 207 5 219 1200
UPSTREAM (Tx)
Noise Margin: 6.0 dB 5.6 dB 5.9 dB 6.1 dB 5.8 dB
Connection Rate: 883 Kbps 883 Kbps 888 Kbps 888 Kbps 888 Kbps
Line Attenuation: 33.3 dB 33.3 dB 33.3 dB 33.3 dB 33.3 dB
Power: 12.9 dBm 12.9 dBm 12.9 dBm 12.9 dBm 12.9 dBm
Max Rate: 888 Kbps 888 Kbps 888 Kbps 888 Kbps 864 Kbps
SuperFrames: 26948 90542 3056 97390 514173
SF (CRC) Errors: 0 0 0 0 0
Reed Solomon: 484524 1627919 55010 1753035 665195
RS Corrected: 0 9 0 102 271
RS Un-Corrected: 0 0 0 0 0
HEC: 0 0 0 0 0
Errored Seconds: 198 198 198 198 198
Severe ES: 0 0 0 0 0
Interleave Depth: 8 8 8 8 8
Bitswaps: 6 28 0 32 197
TOTALS
Total Uptimes (From SF counts):
WAN: 00:08:29 00:28:29 00:00:59 00:30:45 02:42:27
Below are graphs for Bits/Tone graphs for the same time slots as above router stats, also the Noise and sync speed graphs for today.
29-11-2012 11:07 AM
Overall, taking all the recent data and information into account, your line attenuation has increased by 4dB since the 'E' side pair swap, there's clearly a major cable issue (possibly REIN) between the pole and cab, 'D' side swaps have had little effect, and you still get noticeable reductions in Noise Margin of which the damaged untwisted section of drop-wire will be a contributing factor and this will ultimately limit the maximum speed because of the reduced margin.
So what can I conclude from all this -
Well you could be put on a much better pair on the 'E' side, if your original pair weren't actually faulty, they may be the best - 4dB less attenuation!
The damaged untwisted section of drop-wire should be replaced - an easy job, can then be eliminated as any possible contributory factor.
Further investigation of the 'D' side near the electrical cable works is needed. It would seem maybe a REIN engineer may be needed if any other problem cannot be found.
There is a big difference between the bit allocation just before the 1406 test and resync and bit allocation after that. This suggests that there was more noise present when the previous ~2930 sync was achieved, but otherwise the Noise seems fairly constant, so not so much Random as Repetitive and probably not Impulse so much as Continuous Noise!
29-11-2012 12:05 PM
The cable route is mostly underground, but there are a pair of poles through the back of a small group of houses. Between those poles I can see a thick cable (possibly 20-30mm OD?), so that may include my wires.
Anyway, I didn't notice any changes to the radio around the cabinet or electricity sub-station.
However, the only spot where I noticed interference was when standing close to one of the poles that carried the thick cable. There was loud buzz that pulsed 2-3 times per second. I was initially listening at 612kHz so gradually adjusted the frequency. The noise got louder and clearer over 700kHz, but I could still hear it when I went up as far as 800kHz. The sound changed, but the existence of the pulsing was quite consistent.
There is a residential garage about 3 or 4 metres way in one direction. In the other direction, about 1.5 metres, is a lamp post and, about 1 metre further, the back wall of a newish restaurant.
The restaurant was converted from a pub and was opened about 14 months ago, so would have been in its finishing phase of construction about the time my line deteriorated. As a customer of the restaurant I know that they installed lots of new air conditioning and karaoke equipment in the area adjacent to where I was detecting the interference.
29-11-2012 12:11 PM
01-12-2012 2:08 PM
I tuned the radio off station at about 180kHz.
Around the same place as heard the interference on MW, the background buzz got loud. It was different from what I heard at the higher frequencies, more buzzing than pulsing.
When I was at the spot with the buzzing at it loudest, I tuned the radio through the LW range. The buzzing was by far the loudest at the top end of the range, but was audible to some extent through the complete range.
03-12-2012 7:13 AM
The "buzzing" noise that was loudest at the top of the LW band , was it audible and loud down at 522kHz at the bottom of the MW band?
Do either of the noises stop/reduce when you see a reduction in the error rates you mentioned in a PM? The fact that those error rates reduce at the time slots you mentioned is quite significant, especially if it's a pattern that re-occurs.
The other trick is to rotate the radio, as if it were sat on a table and you twisted it round, so the speaker was facing you initially say and then the back of the radio was facing you.. You might be able to get a 'null' direction and see where the line along the length of the radio pointing.
03-12-2012 12:09 PM
This engineer said that he got the same errors as previous engineers, at Master socket. However this time when he tested at the junction on the gable of my house where the cable came from the pole and joined the old cable, he said that there were no errors back to the cabinet/exchange. So he changed the part of the drop cable that was old non twisted pair (I had also pre-drilled a hole through my wall,in a new location, to make it easier).
He then tested the connection and got a speed of approx 4800kbps.
He then connected my router and this is the current ADSL Status:
ADSL Status
Parameters
DSP Firmware Version A2pB025f.d22k
DMT Status No Defect
Operational Mode ADSL2
Upstream 832
Downstream 5003
SNR Margin(Upstream) 6.5
SNR Margin(Downstream) 6.3
Line Attenuation(Upstream) 32.8
Line Attenuation(Downstream) 52.5
Chris Pettitt has increased my profile to match.
@ Anotherone - this may be where you say "I told you so"?
03-12-2012 3:46 PM
04-12-2012 12:08 AM
I can only imagine that as engineer no:2 was full of cold as I recall you mentioning in a PM he may have been testing from the top of the pole to the exchange with the line back to you still connected.
Well I'm so glad that the significant part of your problem looks as though its been overcome, and that the cable entry is now also in a more appropriate location.
The only thing that you mentioned in your PM, not mentioned here, is the drop in SNRM and increase in CRC errors when the phone rings. this is generally symptomatic of a poor joint. Bearing in mind engineer no:2's comments about the top of the pole , this seems a likely probability.
In view of all the current information I'd suggest one more engineer visit was appropriate with 2 specific tasks -
1) To change your 'E' side pair back to your original pair if no better pair is available, the pair you have been put on has 4dB more attenuation and will limit the maximum sync speed.
2) To check and remake the joints at the top of your pole - the only remaining ones that won't have been remade. (The exchange and Cab will be done by the 'E' side swap, your drop-wire joint at the gable and Master socket have just been done).
Anyway the proof of the current pudding is in the eating - any chance of seeing the Bits/Tone and SNRM plots?
04-12-2012 12:29 AM
Some observations:
05:00 - SNRM dropped to about 6dB for the first time in a long time.
10:00 - 11:00 engineer working on line
11:00 - 14:40 a few disconnects possibly due to DLM adjustments, PN testing, and interleave switching on and off on upstream and downstream.
At about 13:30 I remembered to switch on my cordless phone. It had been plugged into the ADSL filter all of the time, but the power wasn't plugged in I saw the SNRM immediately drop by about 1dB so I added the second ADSL filter onto the phone line and it climbed back up again.
04-12-2012 12:50 AM
If your 'E' side was sorted out and 4dB less attenuation, I'd expect to see a few more of the higher tones back on the plot.
04-12-2012 1:06 AM
