Why has my line been changed to interleaved?
- Why has my line been changed to interleaved?
05-08-2011 9:43 AM
Today I noticed that my sync speed is 7616 and on looking at RouterStats, sure enough my line has been changed to interleaved.
I've attached the router stats screen shot - does anyone think 574 FEC errors in over 6 days warrants interleaving?
From looking at latency on my SamKnows monitoring and on the tbb monitor I have found out when it happened - 22nd July:
Re: Why has my line been changed to interleaved?
05-08-2011 9:58 AM
Is the information from routerstats because you have the later version or is it the router
This is what I have
And you left your IP address in if you are bothered
05-08-2011 10:17 AM
Having the IP in an image isn't probably that much of a problem - but I've taken it out anyway - thanks.
05-08-2011 10:30 AM
05-08-2011 10:31 AM
Lets face it, you only noticed cause you looked at the stats (not due to a slow browsing experience)
im guessing a lower-sync' event occured on the 24th? the date is further away than the uptime of your router, you'd need to go back further and see what actualy happened around the 24th surely.
Regards
05-08-2011 11:19 AM
05-08-2011 11:36 AM
05-08-2011 11:40 AM
05-08-2011 12:35 PM
Im guessing that will pop up in your ticket though im sure
Regards
05-08-2011 2:56 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13125525629660.png" />
05-08-2011 3:03 PM
Quote Looking further at the Sam Knows stats the speed has dropped as well.
At 7616 synch, your profile will have dropped to 6500..
05-08-2011 3:11 PM
Quote Download speedachieved during the test was - 5815 Kbps
For your connection, the acceptable range of speeds is 1200-7150 Kbps.
Additional Information:
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
So it is.
When you look at that graph and see "Online for 9 days" and "online for 5 days" it just proves how badly broken the stupid DLM system is! What happened to blip logic that meant one of events are ignored?
I'm not going to see the benefit of the new DLM system either, 21CN isn't even scheduled for this exchange.
05-08-2011 3:15 PM
I've placed the order to turn off interleaving and confirmed this via your ticket.
Jojo
05-08-2011 3:20 PM
I've just tried a disconnect/reboot/reconnect (during which time you posted).
ADSL Link Downstream Upstream
Connection Speed 7616 kbps 832 kbps
Line Attenuation 20 db 6.5 db
Noise Margin 11 db 15 db
Guessing interleaving off could be overnight.
Edit: Just read the ticket. 08/08/11 - oh well just have to be patient
05-08-2011 4:14 PM
