Why does plusnet give more info than other dns servers
9 REPLIES 9
npr
Fixes: 9
Re: Why does plusnet give more info than other dns servers
Don't know about PN's DNS software but with your Pi /  "unbound" try this .conf setting.
minimal-responses: <yes or no>
              If  yes,  Unbound  doesn't  insert authority/additional sections
              into response messages when those  sections  are  not  required.
              This  reduces  response  size  significantly,  and may avoid TCP
              fallback for some responses.  This may cause a  slight  speedup.
              The  default  is no, because the DNS protocol RFCs mandate these
              sections, and the additional content could be of  use  and  save
              roundtrips for clients.
30FTTC06
Fixes: 4
Cheers npr, every little helps.
The little pi is working pretty well these days, it's a case of finding a good Kernel I guess. Out of interest though I'm still curious why more info seems to be given out via plusnet v/s other popular servers.
[tt] thread0.num.queries=119013
thread0.num.cachehits=87748
thread0.num.cachemiss=31265
thread0.num.prefetch=2083
thread0.num.recursivereplies=31265
thread0.requestlist.avg=0.933909
thread0.requestlist.max=12
thread0.requestlist.overwritten=0
thread0.requestlist.exceeded=0
thread0.requestlist.current.all=0
thread0.requestlist.current.user=0
thread0.recursion.time.avg=0.077400
thread0.recursion.time.median=0.0321775
total.num.queries=119013
total.num.cachehits=87748
total.num.cachemiss=31265
total.num.prefetch=2083
total.num.recursivereplies=31265
total.requestlist.avg=0.933909
total.requestlist.max=12
total.requestlist.overwritten=0
total.requestlist.exceeded=0
total.requestlist.current.all=0
total.requestlist.current.user=0
total.recursion.time.avg=0.077400
total.recursion.time.median=0.0321775
time.now=1401381325.066039
time.up=1839023.362245
time.elapsed=1824615.456262[/tt].
npr
Fixes: 9
Smiley  I misread your question.
What tool are you using?
Is it something like dig +trace
; <<>> DiG 9.8.6-P1 <<>> +trace yahoo.com @212.159.6.9
;; global options: +cmd
.                      484570  IN      NS      b.root-servers.net.
.                      484570  IN      NS      f.root-servers.net.
.                      484570  IN      NS      d.root-servers.net.
.                      484570  IN      NS      a.root-servers.net.
.                      484570  IN      NS      j.root-servers.net.
.                      484570  IN      NS      l.root-servers.net.
.                      484570  IN      NS      k.root-servers.net.
.                      484570  IN      NS      h.root-servers.net.
.                      484570  IN      NS      e.root-servers.net.
.                      484570  IN      NS      m.root-servers.net.
.                      484570  IN      NS      c.root-servers.net.
.                      484570  IN      NS      g.root-servers.net.
.                      484570  IN      NS      i.root-servers.net.
;; Received 228 bytes from 212.159.6.9#53(212.159.6.9) in 390 ms
com.                    172800  IN      NS      a.gtld-servers.net.
com.                    172800  IN      NS      b.gtld-servers.net.
com.                    172800  IN      NS      c.gtld-servers.net.
com.                    172800  IN      NS      d.gtld-servers.net.
com.                    172800  IN      NS      e.gtld-servers.net.
com.                    172800  IN      NS      f.gtld-servers.net.
com.                    172800  IN      NS      g.gtld-servers.net.
com.                    172800  IN      NS      h.gtld-servers.net.
com.                    172800  IN      NS      i.gtld-servers.net.
com.                    172800  IN      NS      j.gtld-servers.net.
com.                    172800  IN      NS      k.gtld-servers.net.
com.                    172800  IN      NS      l.gtld-servers.net.
com.                    172800  IN      NS      m.gtld-servers.net.
;; Received 487 bytes from 199.7.83.42#53(l.root-servers.net) in 375 ms
yahoo.com.              172800  IN      NS      ns1.yahoo.com.
yahoo.com.              172800  IN      NS      ns5.yahoo.com.
yahoo.com.              172800  IN      NS      ns2.yahoo.com.
yahoo.com.              172800  IN      NS      ns3.yahoo.com.
yahoo.com.              172800  IN      NS      ns4.yahoo.com.
;; Received 197 bytes from 192.42.93.30#53(g.gtld-servers.net) in 296 ms
yahoo.com.              1800    IN      A      98.138.253.109
yahoo.com.              1800    IN      A      206.190.36.45
yahoo.com.              1800    IN      A      98.139.183.24
yahoo.com.              172800  IN      NS      ns6.yahoo.com.
;; Received 279 bytes from 203.84.221.53#53(ns3.yahoo.com) in 218 ms
30FTTC06
Fixes: 4
dnstracer
sudo dnstracer -s 8.8.8.8 -o -4 yahoo.com
npr
Fixes: 9
I quickly got bored reading the following -- but it doesn't look good.
http://homepage.ntlworld.com/jonathan.deboynepollard/FGA/dnstracer-incorrect-algorithm.html
Don't you have dig in linux Wink
30FTTC06
Fixes: 4
Quite!  Grin
Quickly runs away while typing: sudo apt-get purge dnstracer............
30FTTC06
Fixes: 4
That tweak seems to work better npr, I'll update the post with stats again when I get  hits up around the 100,000 mark in a few days.
I have never seen anything less than 0.03 Previously
[tt]
thread0.num.queries=333
thread0.num.cachehits=287
thread0.num.cachemiss=46
thread0.num.prefetch=0
thread0.num.recursivereplies=46
thread0.requestlist.avg=0.0434783
thread0.recursion.time.avg=0.026126
thread0.recursion.time.median=0.0268516
total.num.queries=333
total.num.cachehits=287
total.num.cachemiss=46
total.num.prefetch=0
total.num.recursivereplies=46
total.requestlist.avg=0.0434783
total.recursion.time.avg=0.026126
total.recursion.time.median=0.0268516
time.now=1401401139.785368
time.up=1858838.081574
time.elapsed=1844430.175591[/tt]
npr
Fixes: 9
That's better than I ever got from the Pi.  Tongue
You've tempted me to have another go.
Which version of linux are you running -- download link if you have it please.  Cheesy
30FTTC06
Fixes: 4
I used bleeding edge updates till i found what worked best for me npr, via "sudo rpi-update" https://github.com/Hexxeh/rpi-update or http://asliceofraspberrypi.blogspot.co.uk/2013/02/updating-your-raspberry-pis-kernel-and.html I'm also still over-clocking as well, it's worth trying the stock version, things have moved on quite a bit, well worth a try though! But i'm sure it won't take you long to rumble the process of finding how to get to the following versions that I'm running.
512MB Version Rpi
Linux  3.10.37+ #669 PREEMPT Tue Apr 15 14:44:32 BST 2014 armv6l GNU/Linux
Apr 23 2014 00:09:02
Copyright (c) 2012 Broadcom
version 8c6eeb8ba935907264625ed86287962173a60e55
Memory split GPU=16
./cpustatus
Temperature: 43.9 C
Voltage: 1.25 V (+0.5)
Min speed: 900 MHz
Max speed: 900 MHz
Current speed: 900 MHzersion
Governor: ondemand
#!/bin/bash
# cpustatus
# Prints the current state of the CPU like temperature, voltage and speed.
# The temperature is reported in degrees Celsius (C) while
# the CPU speed is calculated in megahertz (MHz).
function convert_to_MHz {
let value=$1/1000
echo "$value"
function calculate_overvolts {
# We can safely ignore the integer
# part of the decimal argument
# since it's not realistic to run the Pi
# at voltages higher than 1.99 V
let overvolts=${1#*.}-20
echo "$overvolts"
temp=$(vcgencmd measure_temp)
temp=${temp:5:4}
volts=$(vcgencmd measure_volts)
volts=${volts:5:4}
if [ $volts != "1.20" ]; then
overvolts=$(calculate_overvolts $volts)
fi
minFreq=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq)
minFreq=$(convert_to_MHz $minFreq)
maxFreq=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq)
maxFreq=$(convert_to_MHz $maxFreq)
freq=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq)
freq=$(convert_to_MHz $freq)
governor=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor)
echo "Temperature: $temp C"
echo -n "Voltage: $volts V"
[ $overvolts ] && echo " (+0.$overvolts overvolt)" || echo -e "\r"
echo "Min speed: $minFreq MHz"
echo "Max speed: $maxFreq MHz"
echo "Current speed: $freq MHz"
echo "Governor: $governor"
exit 0
Great little script, i need to find the source and paste the link.
Just shout if you want a copy of my unbound.conf
