Who's good at working out if connection speeds are about right?
- Who's good at working out if connection speeds are...
03-09-2011 5:38 PM
Do these readings indicate any problems to anyone? its 2.52km as crow flys from exchange with the road route i'd say 3k - 3.5k
Mode: ADSL2
Type: ANNEX_A
Status: Showtime
Downstream Upstream
Rate (Kbps): 1208 kbps 471 kbps
SNR Margin (dB): 11.8 15.4
Attenuation (dB): 61.0 36.9
Output Power (dBm): 0.0 12.3
Super Frames: 254023 254020
RS Correctable Errors: 4221 64915
RS Uncorrectable Errors: 1 122
HEC Errors: 3 0
Total Cells: 44109 19851
Data Cells: 1153877 216456
Bit Errors: 0 0
Re: Who's good at working out if connection speeds are about right?
03-09-2011 6:55 PM
Speed is below par but the high SNRM would probably explain that.
So, yes it's about right but why is the SNRM high - some sort of errors on the line are suggested?
04-09-2011 9:15 AM
or shall i wait for you guys to hook it up and get some reasonable solution ?
04-09-2011 9:52 AM
Quote from: richster or shall i wait for you guys to hook it up and get some reasonable solution ?
Absolutely.
The errors may be "historical" or not affect other ISP's kit in the same way.
Post your router stats once you've been connected for quite a few hours, e.g. overnight.
04-09-2011 9:58 AM
04-09-2011 11:51 AM
Quote from: richster talktalk lol
Sorry, got confused with another topic.....
I meant post stats after you've been switched from (TT) to PN and connected for a while.
04-09-2011 1:47 PM
ADSL Modulation : ADSL2
Cable Status : ADSL Link Up
Virtual Circuit : PVC-0PVC-1PVC-2PVC-3PVC-4PVC-5PVC-6PVC-7
Connection Type : PPPoE/PPPoA
Network Status : Connected
Connection Up Time : 0:00:01:21
Downstream Line Rate : 640 kbps
Upstream Line Rate : 465 kbps
Mode: ADSL2
Type: ANNEX_A
Status: Showtime
Downstream Upstream
Rate (Kbps): 640 kbps 465 kbps
SNR Margin (dB): 12.6 14.7
Attenuation (dB): 63.0 36.9
Super Frames: 12326 12330
RS Correctable Errors: 3293 1476
HEC Errors: 1 0
Total Cells: 1003577 444528
Data Cells: 237871 17599
Bit Errors: 0 0
sorry to plus net, were moving to you and hope you can fix our problems later on when were connected
04-09-2011 11:52 PM
05-09-2011 3:15 PM
Sounds like there might have been some interference coming from somewhere on the line, was the BT vision box plugged into the phone line or the ethernet on the router?
Regarding the control of the profile, that's still governed by the DLM equipment at the exchange but we can initiate resets and request profile changes if it's ADSL or ADSL2+. Unfortunately we don't yet have the same control over fibre but that should come along in due time.
If it's a line fault then we'll happily investigate it for you, hopefully it won't be that though - or if it is, fingers crossed it gets resolved with the switchover. Either way please let us know if there's anything we can do once the move is complete
13-09-2011 1:09 AM
....BT
;D.....PLUSNET, Hooray.
Incidentally still on same internal wiring, just for test to prove BT wrong, now got a wireless USB plug in my PC and Thomson router from yourselves is going onto the main socket in another room.
Update, now done this and the wireless connection is showing very good with no loss of download speed.
