Which routers are DD-WRT compatible
NorthEasterner
Whats the cheapest router that is DD-WRT compatible. Needs to be a cable router as connecting to my hub 4
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Re: Which routers are DD-WRT compatible
I would imagine a Linksys or TP-Link router - you would probably find something for £30 or so.
NorthEasterner
A lot of them are linksys or tp link.
But was wondering if anyone knew any model numbers that are DD-WRT compatible.
Fixes: 62
If you used Google as I just did for router dd-wrt compatible you would get the answer
http://www.dd-wrt.com/site/support/router-database which linked to http://www.dd-wrt.com/wiki/index.php/Supported_Devices but with a proviso that it might not be entirely accurate so you should check back with the first link
SuperZoom
With the further proviso that if the need to search for information on your tod is going to be an obstacle, then bricking the router and not being able to fix it is a risk you'll run...    Wink
how about 20 quid? (Only one left in stock)
http://www.amazon.co.uk/TP-Link-TL-WR841N-300Mbps-Wireless-Router/dp/B001FWYGJS/
Hasn't got much memory (flash or ram) and I don't know how well it works with DD-WRT (it is compatible), but here's one happy customer's experience with OpenWRT for inspiration:
https://forum.openwrt.org/viewtopic.php?pid=198363#p198363
Eee, I remember life before Google, when even NCSA Mosaic was a revelation. It has changed lives. Try it: it could change yours!    Tongue
Wulfy
The Dlink 615 (which was given away by virgin) is a great little system and supports dd-wrt absolutely fine probably not hard to get hold of for free/cheap
NorthEasterner
Thanks Wulfy, i'll keep my eye out on the DIR615
There seems to be a few versions , ADSL and Cable
Would I need the cable version?
Wulfy
I use the cable version and it can perform a variety of roles i like its range extender ability's when its acting as a repeater, it can also work with in walled garden setups as well and thats just a small taste of dd-wrt
I'm using a pair of TPLink 841N routers with DD-WRT on.
They cost me £20 each from Amazon but that deal is long gone. Tesco had some in between £32 and £35 each depending on the mood they are in.
Double check the version as there are 4 or 5 .......
