Which routers are DD-WRT compatible
- Re: Which routers are DD-WRT compatible
13-08-2013 10:34 AM
Whats the cheapest router that is DD-WRT compatible. Needs to be a cable router as connecting to my hub 4
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 1 of 9
(4,449 Views)
8 REPLIES 8
13-08-2013 10:39 AM
I would imagine a Linksys or TP-Link router - you would probably find something for £30 or so.
Message 2 of 9
(2,543 Views)
13-08-2013 10:46 AM
A lot of them are linksys or tp link.
But was wondering if anyone knew any model numbers that are DD-WRT compatible.
Message 3 of 9
(2,543 Views)
13-08-2013 10:51 AM
If you used Google as I just did for router dd-wrt compatible you would get the answer
http://www.dd-wrt.com/site/support/router-database which linked to http://www.dd-wrt.com/wiki/index.php/Supported_Devices but with a proviso that it might not be entirely accurate so you should check back with the first link
Message 4 of 9
(2,543 Views)
13-08-2013 11:22 AM
With the further proviso that if the need to search for information on your tod is going to be an obstacle, then bricking the router and not being able to fix it is a risk you'll run...
how about 20 quid? (Only one left in stock)
http://www.amazon.co.uk/TP-Link-TL-WR841N-300Mbps-Wireless-Router/dp/B001FWYGJS/
Hasn't got much memory (flash or ram) and I don't know how well it works with DD-WRT (it is compatible), but here's one happy customer's experience with OpenWRT for inspiration:
https://forum.openwrt.org/viewtopic.php?pid=198363#p198363
Eee, I remember life before Google, when even NCSA Mosaic was a revelation. It has changed lives. Try it: it could change yours!
Message 5 of 9
(2,543 Views)
13-08-2013 11:23 AM
The Dlink 615 (which was given away by virgin) is a great little system and supports dd-wrt absolutely fine probably not hard to get hold of for free/cheap
Message 6 of 9
(2,543 Views)
13-08-2013 4:38 PM
Thanks Wulfy, i'll keep my eye out on the DIR615
There seems to be a few versions , ADSL and Cable
Would I need the cable version?
Message 7 of 9
(2,543 Views)
13-08-2013 5:15 PM
I use the cable version and it can perform a variety of roles i like its range extender ability's when its acting as a repeater, it can also work with in walled garden setups as well and thats just a small taste of dd-wrt
Message 8 of 9
(2,543 Views)
13-08-2013 6:02 PM
I'm using a pair of TPLink 841N routers with DD-WRT on.
They cost me £20 each from Amazon but that deal is long gone. Tesco had some in between £32 and £35 each depending on the mood they are in.
Double check the version as there are 4 or 5 .......
Message 9 of 9
(2,543 Views)
