Which router ?
- Which router ?
- « Previous
- 1
- 2
- Next »
Re: Which router ?
16-02-2008 12:24 PM
Thanks for that, I will rest easy
Message 16 of 20
(257 Views)
Re: Which router ?
16-02-2008 1:08 PM
ok thanks everyone for your help
the 3com Officonnect is a bit too pricey so Netgear DG834 it is
Message 17 of 20
(257 Views)
Re: Which router ?
16-02-2008 8:04 PM
You may also want to consider Draytek: http://www.draytek.co.uk/products/index.html
I don't know if they are more than what you are after in terms of features, performance and price, but if I were to buy another modem/router combo at this price range (domestic grade) that's what I would go for.
Hope this helps.
Regards,
Mick
Hope this helps.
Regards,
Mick
Message 18 of 20
(257 Views)
Re: Which router ?
16-02-2008 10:47 PM
Quote from: john
A v3 Firmware update is out now dated Jan' 2008
Where can you find it - it's not on Netgear's site? The last one there is September 5 2007.
http://kbserver.netgear.com/products/DG834Gv3.asp
Message 19 of 20
(257 Views)
Re: Which router ?
17-02-2008 12:35 PM
Quote from: barquerole
Quote from: john
My mistake, its dated as you say Sept 5, 2007
Message 20 of 20
(257 Views)
- « Previous
- 1
- 2
- Next »
