Which router ?
- Which router ?
Which router ?
15-02-2008 7:30 PM
My problem is i dont have a clue what to look for. My friend has a Netgear Wireless-G DGB111G and has no problems but ive been looking at the Netgear DG834UK ADSL Router.
I'm looking to spend around £40 or £50
Can anyone help with what i should be looking for or advise on a product ?
thx in advance
Re: Which router ?
15-02-2008 7:31 PM
Re: Which router ?
15-02-2008 7:36 PM
Re: Which router ?
15-02-2008 8:03 PM
I'd say go for it.
Re: Which router ?
15-02-2008 8:09 PM
Quote from: Loombucket its been around since Adam was a lad
Yes, but Adam did prefer Apple's though didn't he?
/Back on topic...
I'd also say that you can't go far wrong with Netgear stuff. Its as well made and reliable as many other brands, its well supported, and easier to understand than many other ones (IMO)
Re: Which router ?
15-02-2008 8:30 PM
I've got a DG834GT by the way.
Re: Which router ?
15-02-2008 9:35 PM
Re: Which router ?
15-02-2008 9:44 PM
I'd like to look at changing to a chipset that's not affected by this issue but I can't find the details anymore.
A
Re: Which router ?
15-02-2008 10:10 PM
There is some very good RouterStats proggy's about for this Modem/Router
http://www.vwlowen.co.uk/internet/files.htm#routerstats
Re: Which router ?
16-02-2008 12:49 AM
Re: Which router ?
16-02-2008 6:59 AM
Re: Which router ?
16-02-2008 9:09 AM
The earlier versions have an AR-7 chipset which is prone to line drops, particularly on longer lines.
Netgear were supposed to be bringing out an upgrade to the firmware for v3 to counter this problem, but they haven't done it yet.
Re: Which router ?
16-02-2008 11:19 AM
Quote from: barquerole If you are going to buy a Netgear 834G, make sure you get v4, which uses a Broadcom chipset.
A v3 Firmware update is out now dated Jan' 2008
The DG 834 I purchased this week is actually a v3
Re: Which router ?
16-02-2008 11:26 AM
Linky - http://www.morecomputers.com/extra.asp?pn=3CRWDR200A-75-UK
Re: Which router ?
16-02-2008 12:02 PM
Quote from: john
Don't worry - the DG834 latest revision is v3 which is fine. The DG834G (like the 834 but with wireless) v3 has issues which were fixed with the v4.
Rest easy, you've got the latest revision and it's a great little unit - unusually tenacious when dealing with a poor ADSL signal. I've supplied and installed dozens over the last 3 or 4 years with not a single problem or failure.
