Which gateway?
sully666
Which gateway?
With all the slow speeds over the weekend and issues with certain gateways, I wondered how I found out which gateway I am connected to.
Fixes: 131
Re: Which gateway?
http://usertools.plus.net/@gateway/
Customer and Forum Moderator.
Fixes: 10
Re: Which gateway?
Or you can see at as the second hop on a tracert:
C:\Users\John>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.13.49]
over a maximum of 30 hops:
  1    3 ms    5 ms    1 ms  tg582 [192.168.1.254]
  2    69 ms    20 ms    21 ms  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
  3    20 ms    21 ms    20 ms  link-a-central10.pcl-gw01.plus.net [212.159.2.168]
  4    21 ms    20 ms    20 ms  xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
  5    24 ms    21 ms    20 ms  po2.pcl-gw01.plus.net [195.166.129.41]
  6    21 ms    21 ms    21 ms  vl63.pcl-lb01.plus.net [212.159.2.252]
  7    22 ms    20 ms    21 ms  cdns01.plus.net [212.159.13.49]
Trace complete.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
