Which connection is used
- Which connection is used
28-07-2008 7:55 AM
Curious as to which connection PC uses, when it has a wired 100mbps
& a 54 wireless connection from same router, as to which one it defaults to re Interconnect speed?
Message 1 of 6
(1,527 Views)
5 REPLIES 5
Re: Which connection is used
28-07-2008 8:21 AM
dont get too confused, probably the 100M is the ethernet connection RJ45 the 50 the USB, wiless is not as fast
Message 2 of 6
(674 Views)
28-07-2008 12:26 PM
Gel, if you do a route print from a command prompt you will get something like this:
[tt]===========================================================================
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 05 4e 4f 68 ca ...... 11a/b/g Wireless LAN Mini PCI Adapter - AGN Filter Interface
0x3 ...00 0d 60 d0 4b 94 ...... Intel(R) PRO/1000 MT Mobile Connection - AGN Filter Interface
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 9.175.169.1 9.175.169.36 10
9.175.169.0 255.255.255.128 9.175.169.36 9.175.169.36 10
9.175.169.36 255.255.255.255 127.0.0.1 127.0.0.1 10
9.255.255.255 255.255.255.255 9.175.169.36 9.175.169.36 10
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
224.0.0.0 240.0.0.0 9.175.169.36 9.175.169.36 10
255.255.255.255 255.255.255.255 9.175.169.36 9.175.169.36 1
255.255.255.255 255.255.255.255 9.175.169.36 2 1
Default Gateway: 9.175.169.1
===========================================================================[/tt]
The Metric on the right hand end is a weighting and the system will always use the lowest weighted route available. You should find that your 100M route has a lower weighting than the wireless one and therefore the 100M will be used in preference to the wireless.
Interface List
Active Routes:
Message 3 of 6
(674 Views)
29-07-2008 5:30 PM
David thanks; on my XP2 SP3 machine the command works but the pop up box disappears from screen in a nano second
Message 4 of 6
(674 Views)
29-07-2008 5:35 PM
I think you need to open a DOS windows by typing CMD in the run box then typing the command in the DOS window
Message 5 of 6
(674 Views)
31-07-2008 6:07 PM
Many thanks; that worked.
Wired connection has a lower metric as you say of 20, versus 25 for Wifi.
Message 6 of 6
(674 Views)
