Which Netgear router would you recommend?
KenA
Hello,
I'm looking for a recommendation to solve a forthcoming question.
I manage three sites, and each one has ADSL over a BT phone line.  All three have a Netgear DG834G modem/router, and I specifically use the VPN function within the Netgears to allow computers on the three subnets to communicate.
However, we're adding a fourth site which will be connected via cable internet, and I need to procure another Netgear router which has the same VPN capability as the DG834G, but needs to be a cable modem/router, rather than an ADSL modem/router.
Which model would you recommend that can handle this task?
And I cannot consider replacing all of them, so the new one must work with the existing ones.
