Which Gateway when on alternative gateway (BT)
- Which Gateway when on alternative gateway (BT)
02-03-2008 8:20 AM
ever work when on the alternative ISP gateway to standard Plus Net address?
Re: Which Gateway when on alternative gateway (BT)
02-03-2008 9:10 AM
02-03-2008 9:45 AM
02-03-2008 11:00 AM
Quote from: Peter What gateway is not showing up correctly?
Dont know, none show
02-03-2008 11:56 AM
02-03-2008 11:59 AM
02-03-2008 12:11 PM
02-03-2008 12:14 PM
Hope that helps,
02-03-2008 12:52 PM
02-03-2008 3:06 PM
in Win98 run command to get a dos box then run the tracert command within it. You can then scroll up if it has gone off the screen.
02-03-2008 3:49 PM
03-03-2008 12:25 PM
Quote You are currently connected to the "City Lifeline, Juniper 8" gateway. This gateway is sometimes known as pcl-ag01.
Can you check if that is what you are on as I can see you typed it and there is a zero missing in the name you gave - that might explain the error.
03-03-2008 12:55 PM
03-03-2008 1:00 PM
Quote Which gateway
You are currently connected to the "Telehouse East, Juniper 3" gateway. This gateway is sometimes known as pte-ag1.
tried tracert again, but it went so quick I didnt see anything
03-03-2008 1:15 PM
Type cmd into the run box, the type the tracert syntax into the command prompt.
The results will stay on your screen then.
