Which Gateway ptn-ag03 and others
- Which Gateway ptn-ag03 and others
13-07-2012 11:14 AM
Re: Which Gateway ptn-ag03
13-07-2012 11:38 AM
There are likely to be more, given our recent work to Traffic Management rollouts, so keep them coming.
If you do not mind, can you use the following link if you see more.
http://users.plus.net/@gateway_custom?debug-ip=1
We need the bit marked between array, which will help us show what is needed (incase you reconnect between you posting and us seeing it).
Example
Array
[0] => 1 vl7.sec.ptb-gw4.plus.net (212.159.3.25) 0.591 ms
[1] => 2 vl421.pih-gw3.plus.net (212.159.1.171) 0.572 ms
[2] => 3 gi1-1.ptn-gw01.plus.net (212.159.1.178) 11.708 ms
[3] => 4 ae3.ptw-cr01.plus.net (195.166.129.32) 11.339 ms
[4] => 5 33.core.plus.net (212.159.1.33) 11.972 ms
[5] => 6 84.93.248.197.broadband.plus.dyn.plus.net (84.93.248.197) 13.719 ms
[6] => 7 *
[7] => 8 *
[8] => 9 *
13-07-2012 5:19 PM
Array
[0] => 1 vl7.sec.ptb-gw4.plus.net (212.159.3.25) 0.609 ms
[1] => 2 vl427.pih-gw3.plus.net (212.159.1.123) 0.565 ms
[2] => 3 gi1-1.ptn-gw01.plus.net (212.159.1.178) 15.952 ms
[3] => 4 ae3.ptw-cr01.plus.net (195.166.129.32) 11.717 ms
[4] => 5 ae1.pcl-cr01.plus.net (195.166.129.1) 21.864 ms
[5] => 6 pte-sw5 (212.159.1.5) 12.507 ms
[6] => 7 84.93.249.69.broadband.plus.dyn.plus.net (84.93.249.69) 13.445 ms
[7] => 8 *
[8] => 9 *
Re: Which Gateway ptn-ag03 and others
13-07-2012 7:51 PM
lo0-central10.ptn-ag02.plus.net [195.166.128.191]
[0] => 1 vl7.sec.ptb-gw4.plus.net (212.159.3.25) 0.582 ms
[1] => 2 vl421.pih-gw3.plus.net (212.159.1.171) 0.557 ms
[2] => 3 gi1-1.ptn-gw01.plus.net (212.159.1.178) 11.712 ms
[3] => 4 ae3.ptw-cr01.plus.net (195.166.129.32) 11.423 ms
[4] => 5 29.core.plus.net (212.159.1.29) 11.963 ms
[5] => 6 84.93.248.165.broadband.plus.dyn.plus.net (84.93.248.165) 13.334 ms
[6] => 7 username.plus.com (81.174.xxx.xxx)
Sorry, can't get the formatting right for the last line '[6]=> 7 username....'
16-07-2012 9:58 AM
16-07-2012 10:47 AM
lo0-central10.ptw-ag02.plus.net [195.166.128.196]
Array
[0] => 1 vl7.sec.ptb-gw4.plus.net (212.159.3.25) 0.619 ms
[1] => 2 vl421.pih-gw3.plus.net (212.159.1.171) 0.570 ms
[2] => 3 gi1-1.ptn-gw01.plus.net (212.159.1.178) 11.717 ms
[3] => 4 ae3.ptw-cr01.plus.net (195.166.129.32) 12.425 ms
[4] => 5 *
[5] => 6 84.93.248.49.broadband.plus.dyn.plus.net (84.93.248.49) 17.387 ms
[6] => 7 *
[7] => 8 *
[8] => 9 *
16-07-2012 10:48 AM
17-07-2012 9:47 AM
17-07-2012 11:16 AM
lo0-central10.pcl-ag08.plus.net [195.166.128.189]
Array
[0] => 1 vl7.sec.ptb-gw4.plus.net (212.159.3.25) 0.628 ms
[1] => 2 vl427.pih-gw3.plus.net (212.159.1.123) 0.561 ms
[2] => 3 gi1-1.ptn-gw01.plus.net (212.159.1.178) 11.839 ms
[3] => 4 ae3.ptw-cr01.plus.net (195.166.129.32) 11.667 ms
[4] => 5 ae1.pcl-cr01.plus.net (195.166.129.1) 11.712 ms
[5] => 6 nte2.bt622-11.plus.net (212.159.1.13) 16.175 ms
[6] => 7 84.93.249.241.broadband.plus.dyn.plus.net (84.93.249.241) 12.964 ms
[7] => 8 *
[8] => 9 *
17-07-2012 1:51 PM
PS if some of you could try using this tool and post the results back here that would be useful too:
http://www.giganews.com/line_info.html
17-07-2012 2:25 PM
1 gw1-g-vlan201.dca.giganews.com (216.196.98.4) 1 ms 0 ms 0 ms
2 xe-2-3-0.er1.iad10.us.above.net (209.66.64.189) 0 ms 0 ms 0 ms
3 xe-0-0-0.er2.iad10.us.above.net (64.125.26.234) 0 ms 0 ms 0 ms
4 above-level3.iad10.us.above.net (64.125.13.234) 0 ms 0 ms 0 ms
5 vlan80.csw3.Washington1.Level3.net (4.69.149.190) 8 ms vlan70.csw2.Washington1.Level3.net (4.69.149.126) 1 ms vlan60.csw1.Washington1.Level3.net (4.69.149.62) 11 ms
MPLS Label=1132 CoS=0 TTL=0 S=1
6 ae-72-72.ebr2.Washington1.Level3.net (4.69.134.149) 0 ms ae-62-62.ebr2.Washington1.Level3.net (4.69.134.145) 1 ms ae-72-72.ebr2.Washington1.Level3.net (4.69.134.149) 0 ms
MPLS Label=1068 CoS=0 TTL=0 S=1
7 ae-3-3.ebr1.NewYork2.Level3.net (4.69.132.90) 6 ms 11 ms 6 ms
MPLS Label=1192 CoS=0 TTL=0 S=1
8 ae-4-4.ebr1.NewYork1.Level3.net (4.69.141.17) 6 ms 4.69.148.49 (4.69.148.49) 6 ms ae-4-4.ebr1.NewYork1.Level3.net (4.69.141.17) 6 ms
MPLS Label=1116 CoS=0 TTL=0 S=1
9 ae-43-43.ebr2.London1.Level3.net (4.69.137.73) 74 ms ae-44-44.ebr2.London1.Level3.net (4.69.137.77) 75 ms 75 ms
MPLS Label=1209 CoS=0 TTL=0 S=1
10 ae-56-221.csw2.London1.Level3.net (4.69.153.130) 75 ms ae-58-223.csw2.London1.Level3.net (4.69.153.138) 77 ms ae-56-221.csw2.London1.Level3.net (4.69.153.130) 75 ms
MPLS Label=1214 CoS=0 TTL=0 S=1
11 ae-25-52.car5.London1.Level3.net (4.69.139.102) 75 ms 77 ms 81 ms
12 PLUSNET-TEC.car5.London1.Level3.net (217.163.45.182) 75 ms 74 ms 75 ms
13 ae2.ptw-cr02.plus.net (195.166.129.5) 74 ms 74 ms 75 ms
MPLS Label=379520 CoS=0 TTL=0 S=1
14 ae1.pcl-cr02.plus.net (195.166.129.3) 76 ms 105 ms 75 ms
15 mn-gw1.plus.net (212.159.1.7) 77 ms 76 ms 176 ms
MPLS Label=493 CoS=0 TTL=0 S=1
16 84.93.249.71.broadband.plus.dyn.plus.net (84.93.249.71) 76 ms 85 ms 76 ms
17 * * *
18 * * *
19 * * *
Max number of unresponsive hops reached (firewall or filter?)
news-europe.giganews.com
1 vl201.gw2.ams.giganews.com (216.196.110.2) 0 ms 0 ms 0 ms
2 216-196-108-186.ams.giganews.com (216.196.108.186) 0 ms 216-196-108-178.ams.giganews.com (216.196.108.178) 0 ms 216-196-108-186.ams.giganews.com (216.196.108.186) 0 ms
3 linx-gw1.plus.net (195.66.224.164) 7 ms 7 ms 7 ms
4 ae2.ptw-cr02.plus.net (195.166.129.5) 10 ms 7 ms 7 ms
5 ae1.pcl-cr02.plus.net (195.166.129.3) 7 ms 7 ms 7 ms
6 mn-gw1.plus.net (212.159.1.7) 11 ms 74 ms 9 ms
MPLS Label=1140 CoS=0 TTL=0 S=1
7 84.93.249.79.broadband.plus.dyn.plus.net (84.93.249.79) 13 ms 8 ms 9 ms
8 * * *
9 * * *
10 * * *
17-07-2012 2:38 PM
1 gw1-g-vlan201.dca.giganews.com (216.196.98.4) 0 ms 0 ms 0 ms
5 vlan90.csw4.Washington1.Level3.net (4.69.149.254) 6 ms vlan60.csw1.Washington1.Level3.net (4.69.149.62) 1 ms vlan80.csw3.Washington1.Level3.net (4.69.149.190) 6 ms
MPLS Label=1258 CoS=0 TTL=0 S=1
6 ae-82-82.ebr2.Washington1.Level3.net (4.69.134.153) 0 ms 2 ms ae-72-72.ebr2.Washington1.Level3.net (4.69.134.149) 0 ms
7 ae-5-5.ebr2.Washington12.Level3.net (4.69.143.222) 8 ms 0 ms 10 ms
MPLS Label=1311 CoS=0 TTL=0 S=1
8 ae-4-4.ebr1.NewYork1.Level3.net (4.69.141.17) 6 ms 6 ms 4.69.148.49 (4.69.148.49) 6 ms
9 ae-44-44.ebr2.London1.Level3.net (4.69.137.77) 74 ms 74 ms ae-41-41.ebr2.London1.Level3.net (4.69.137.65) 74 ms
10 ae-57-222.csw2.London1.Level3.net (4.69.153.134) 78 ms 77 ms ae-58-223.csw2.London1.Level3.net (4.69.153.138) 82 ms
11 ae-25-52.car5.London1.Level3.net (4.69.139.102) 75 ms 80 ms 75 ms
12 PLUSNET-TEC.car5.London1.Level3.net (217.163.45.182) 75 ms 75 ms 76 ms
13 te9-4.ptn-gw01.plus.net (195.166.129.33) 157 ms 260 ms 221 ms
MPLS Label=23 CoS=0 TTL=0 S=1
14 gi11-1-0-111.ptn-ag01.plus.net (84.92.3.136) 85 ms 77 ms 78 ms
15 * * *
16 * * *
17 * * *
2 216-196-108-178.ams.giganews.com (216.196.108.178) 0 ms 216-196-108-186.ams.giganews.com (216.196.108.186) 0 ms vl305.gw1.ams.giganews.com (216.196.108.226) 0 ms
4 te9-4.ptn-gw01.plus.net (195.166.129.33) 9 ms 8 ms 7 ms
5 gi11-1-0-111.ptn-ag01.plus.net (84.92.3.136) 9 ms 9 ms 8 ms
6 * * *
7 * * *
8 * * *
18-07-2012 5:54 PM
23-07-2012 12:04 PM
24-07-2012 11:02 AM
It is presently only active for 21CN and is only awaiting some changes supplier side for 20CN.
In the last few weeks, there are higher priority items to resolve, including the traffic management rollout itself and to obvious capacity work we are doing for the "mass sporting events"
Once we have the time available, these DNS changes should be relatively simple. Us adding to the problem means we are able to collate all updates to be completed in a single batch.
