Which Gateway ptn-ag03 and others
Anotherone
Champion
Fixes: 21
Since the Traffic Management work last night the Usertools Gateway checker isn't recognising lo0-central10.ptn-ag03.plus.net [195.166.128.192]
15 REPLIES 15
prichardson
Re: Which Gateway ptn-ag03
I've raised problem 72074 on this.
There are likely to be more, given our recent work to Traffic Management rollouts, so keep them coming.
If you do not mind, can you use the following link if you see more.
http://users.plus.net/@gateway_custom?debug-ip=1
We need the bit marked between array, which will help us show what is needed (incase you reconnect between you posting and us seeing it).
Example
Array
    [0] =>  1  vl7.sec.ptb-gw4.plus.net (212.159.3.25)  0.591 ms
    [1] =>  2  vl421.pih-gw3.plus.net (212.159.1.171)  0.572 ms
    [2] =>  3  gi1-1.ptn-gw01.plus.net (212.159.1.178)  11.708 ms
    [3] =>  4  ae3.ptw-cr01.plus.net (195.166.129.32)  11.339 ms
    [4] =>  5  33.core.plus.net (212.159.1.33)  11.972 ms
    [5] =>  6  84.93.248.197.broadband.plus.dyn.plus.net (84.93.248.197)  13.719 ms
    [6] =>  7  *
    [7] =>  8  *
    [8] =>  9  *
Anotherone
Champion
Fixes: 21
And another lo0-central10.pcl-ag03.plus.net [195.166.128.184]
Array
    [0] =>  1  vl7.sec.ptb-gw4.plus.net (212.159.3.25)  0.609 ms
    [1] =>  2  vl427.pih-gw3.plus.net (212.159.1.123)  0.565 ms
    [2] =>  3  gi1-1.ptn-gw01.plus.net (212.159.1.178)  15.952 ms
    [3] =>  4  ae3.ptw-cr01.plus.net (195.166.129.32)  11.717 ms
    [4] =>  5  ae1.pcl-cr01.plus.net (195.166.129.1)  21.864 ms
    [5] =>  6  pte-sw5 (212.159.1.5)  12.507 ms
    [6] =>  7  84.93.249.69.broadband.plus.dyn.plus.net (84.93.249.69)  13.445 ms
    [7] =>  8  *
    [8] =>  9  *
w23
Fixes: 4
Re: Which Gateway ptn-ag03 and others
Sorry, the tool currently could not identify your gateway; this does not mean that anything is wrong with your connection:
lo0-central10.ptn-ag02.plus.net [195.166.128.191]
[0] =>  1  vl7.sec.ptb-gw4.plus.net (212.159.3.25)  0.582 ms
[1] =>  2  vl421.pih-gw3.plus.net (212.159.1.171)  0.557 ms
[2] =>  3  gi1-1.ptn-gw01.plus.net (212.159.1.178)  11.712 ms
[3] =>  4  ae3.ptw-cr01.plus.net (195.166.129.32)  11.423 ms
[4] =>  5  29.core.plus.net (212.159.1.29)  11.963 ms
[5] =>  6  84.93.248.165.broadband.plus.dyn.plus.net (84.93.248.165)  13.334 ms
[6] =>  7  username.plus.com (81.174.xxx.xxx)
Sorry, can't get the formatting right for the last line '[6]=>  7  username....'
Call me 'w23'
adamwalker
Fixes: 221
72074 is still open but I've put a "watch" on it so I'll keep an eye out for updates.
@walker23 I've added your example to that problem as it seems to be an issue for ptn-ag02 too.
 Adam Walker
pengyou
Sorry, the tool currently could not identify your gateway; this does not mean that anything is wrong with your connection.
lo0-central10.ptw-ag02.plus.net [195.166.128.196]
Array
    [0] =>  1  vl7.sec.ptb-gw4.plus.net (212.159.3.25)  0.619 ms
    [1] =>  2  vl421.pih-gw3.plus.net (212.159.1.171)  0.570 ms
    [2] =>  3  gi1-1.ptn-gw01.plus.net (212.159.1.178)  11.717 ms
    [3] =>  4  ae3.ptw-cr01.plus.net (195.166.129.32)  12.425 ms
    [4] =>  5  *
    [5] =>  6  84.93.248.49.broadband.plus.dyn.plus.net (84.93.248.49)  17.387 ms
    [6] =>  7  *
    [7] =>  8  *
    [8] =>  9  *
Anotherone
Champion
Fixes: 21
You added pcl-ag03 as well (reply #2) I trust, ptn-ag03 being the one I started the thread with  Wink
adamwalker
Fixes: 221
Yes, that's been added too.
 Adam Walker
pengyou
lo0-central10.pcl-ag08.plus.net [195.166.128.189]
Array
    [0] =>  1  vl7.sec.ptb-gw4.plus.net (212.159.3.25)  0.628 ms
    [1] =>  2  vl427.pih-gw3.plus.net (212.159.1.123)  0.561 ms
    [2] =>  3  gi1-1.ptn-gw01.plus.net (212.159.1.178)  11.839 ms
    [3] =>  4  ae3.ptw-cr01.plus.net (195.166.129.32)  11.667 ms
    [4] =>  5  ae1.pcl-cr01.plus.net (195.166.129.1)  11.712 ms
    [5] =>  6  nte2.bt622-11.plus.net (212.159.1.13)  16.175 ms
    [6] =>  7  84.93.249.241.broadband.plus.dyn.plus.net (84.93.249.241)  12.964 ms
    [7] =>  8  *
    [8] =>  9  *
adamwalker
Fixes: 221
I'll add that to the problem too, it definitely sounds like the issue is across the board. We can see that resolving this is dependent on updating the associated PTR records.
PS if some of you could try using this tool and post the results back here that would be useful too:
http://www.giganews.com/line_info.html
 Adam Walker
Anotherone
Champion
Fixes: 21
news.giganews.com
1 gw1-g-vlan201.dca.giganews.com (216.196.98.4) 1 ms 0 ms 0 ms
2 xe-2-3-0.er1.iad10.us.above.net (209.66.64.189) 0 ms 0 ms 0 ms
3 xe-0-0-0.er2.iad10.us.above.net (64.125.26.234) 0 ms 0 ms 0 ms
4 above-level3.iad10.us.above.net (64.125.13.234) 0 ms 0 ms 0 ms
5 vlan80.csw3.Washington1.Level3.net (4.69.149.190) 8 ms vlan70.csw2.Washington1.Level3.net (4.69.149.126) 1 ms vlan60.csw1.Washington1.Level3.net (4.69.149.62) 11 ms
MPLS Label=1132 CoS=0 TTL=0 S=1
6 ae-72-72.ebr2.Washington1.Level3.net (4.69.134.149) 0 ms ae-62-62.ebr2.Washington1.Level3.net (4.69.134.145) 1 ms ae-72-72.ebr2.Washington1.Level3.net (4.69.134.149) 0 ms
MPLS Label=1068 CoS=0 TTL=0 S=1
7 ae-3-3.ebr1.NewYork2.Level3.net (4.69.132.90) 6 ms 11 ms 6 ms
MPLS Label=1192 CoS=0 TTL=0 S=1
8 ae-4-4.ebr1.NewYork1.Level3.net (4.69.141.17) 6 ms 4.69.148.49 (4.69.148.49) 6 ms ae-4-4.ebr1.NewYork1.Level3.net (4.69.141.17) 6 ms
MPLS Label=1116 CoS=0 TTL=0 S=1
9 ae-43-43.ebr2.London1.Level3.net (4.69.137.73) 74 ms ae-44-44.ebr2.London1.Level3.net (4.69.137.77) 75 ms 75 ms
MPLS Label=1209 CoS=0 TTL=0 S=1
10 ae-56-221.csw2.London1.Level3.net (4.69.153.130) 75 ms ae-58-223.csw2.London1.Level3.net (4.69.153.138) 77 ms ae-56-221.csw2.London1.Level3.net (4.69.153.130) 75 ms
MPLS Label=1214 CoS=0 TTL=0 S=1
11 ae-25-52.car5.London1.Level3.net (4.69.139.102) 75 ms 77 ms 81 ms
12 PLUSNET-TEC.car5.London1.Level3.net (217.163.45.182) 75 ms 74 ms 75 ms
13 ae2.ptw-cr02.plus.net (195.166.129.5) 74 ms 74 ms 75 ms
MPLS Label=379520 CoS=0 TTL=0 S=1
14 ae1.pcl-cr02.plus.net (195.166.129.3) 76 ms 105 ms 75 ms
15 mn-gw1.plus.net (212.159.1.7) 77 ms 76 ms 176 ms
MPLS Label=493 CoS=0 TTL=0 S=1
16 84.93.249.71.broadband.plus.dyn.plus.net (84.93.249.71) 76 ms 85 ms 76 ms
17 * * *
18 * * *
19 * * *
Max number of unresponsive hops reached (firewall or filter?)
news-europe.giganews.com
1 vl201.gw2.ams.giganews.com (216.196.110.2) 0 ms 0 ms 0 ms
2 216-196-108-186.ams.giganews.com (216.196.108.186) 0 ms 216-196-108-178.ams.giganews.com (216.196.108.178) 0 ms 216-196-108-186.ams.giganews.com (216.196.108.186) 0 ms
3 linx-gw1.plus.net (195.66.224.164) 7 ms 7 ms 7 ms
4 ae2.ptw-cr02.plus.net (195.166.129.5) 10 ms 7 ms 7 ms
5 ae1.pcl-cr02.plus.net (195.166.129.3) 7 ms 7 ms 7 ms
6 mn-gw1.plus.net (212.159.1.7) 11 ms 74 ms 9 ms
MPLS Label=1140 CoS=0 TTL=0 S=1
7 84.93.249.79.broadband.plus.dyn.plus.net (84.93.249.79) 13 ms 8 ms 9 ms
8 * * *
9 * * *
10 * * *
32110
news.giganews.com
1 gw1-g-vlan201.dca.giganews.com (216.196.98.4) 0 ms 0 ms 0 ms
5 vlan90.csw4.Washington1.Level3.net (4.69.149.254) 6 ms vlan60.csw1.Washington1.Level3.net (4.69.149.62) 1 ms vlan80.csw3.Washington1.Level3.net (4.69.149.190) 6 ms
MPLS Label=1258 CoS=0 TTL=0 S=1
6 ae-82-82.ebr2.Washington1.Level3.net (4.69.134.153) 0 ms 2 ms ae-72-72.ebr2.Washington1.Level3.net (4.69.134.149) 0 ms
7 ae-5-5.ebr2.Washington12.Level3.net (4.69.143.222) 8 ms 0 ms 10 ms
MPLS Label=1311 CoS=0 TTL=0 S=1
8 ae-4-4.ebr1.NewYork1.Level3.net (4.69.141.17) 6 ms 6 ms 4.69.148.49 (4.69.148.49) 6 ms
9 ae-44-44.ebr2.London1.Level3.net (4.69.137.77) 74 ms 74 ms ae-41-41.ebr2.London1.Level3.net (4.69.137.65) 74 ms
10 ae-57-222.csw2.London1.Level3.net (4.69.153.134) 78 ms 77 ms ae-58-223.csw2.London1.Level3.net (4.69.153.138) 82 ms
11 ae-25-52.car5.London1.Level3.net (4.69.139.102) 75 ms 80 ms 75 ms
12 PLUSNET-TEC.car5.London1.Level3.net (217.163.45.182) 75 ms 75 ms 76 ms
13 te9-4.ptn-gw01.plus.net (195.166.129.33) 157 ms 260 ms 221 ms
MPLS Label=23 CoS=0 TTL=0 S=1
14 gi11-1-0-111.ptn-ag01.plus.net (84.92.3.136) 85 ms 77 ms 78 ms
15 * * *
16 * * *
17 * * *
2 216-196-108-178.ams.giganews.com (216.196.108.178) 0 ms 216-196-108-186.ams.giganews.com (216.196.108.186) 0 ms vl305.gw1.ams.giganews.com (216.196.108.226) 0 ms
4 te9-4.ptn-gw01.plus.net (195.166.129.33) 9 ms 8 ms 7 ms
5 gi11-1-0-111.ptn-ag01.plus.net (84.92.3.136) 9 ms 9 ms 8 ms
6 * * *
7 * * *
8 * * *
adamwalker
Fixes: 221
Thanks guys, I've added those to the problem and I'll make sure we let you know when that's been fixed.
 Adam Walker
Anotherone
Champion
Fixes: 21
I don't suppose there will any movement on this until pcl-ag08 is back up and running at least?
prichardson
PCL-AG08 is now back up and running.
It is presently only active for 21CN and is only awaiting some changes supplier side for 20CN.
In the last few weeks, there are higher priority items to resolve, including the traffic management rollout itself and to obvious capacity work we are doing for the "mass sporting events" Cheesy
Once we have the time available, these DNS changes should be relatively simple. Us adding to the problem means we are able to collate all updates to be completed in a single batch.
