Which DLM profile do PN provision FTTC lines on?
AndyH
Question has popped up a couple of times recently (http://forums.thinkbroadband.com/plusnet/4282360-can-plusnet-change-fttc-dlm-settings.html).
From Openreach (http://www.openreach.co.uk/orpg/home/products/super-fastfibreaccess/fibretothecabinet/fttc/downloads/GEA_FTTC_4.pdf):
Match the way a line is managed to the way  your customer uses it:
Standard – best overall balance between speed and stability for general internet users
Stable – prioritise stability over speed for  IPTV videoconferencing, home workers and businesses transferring data and IPTV
Speed – prioritise speed over stability for online gamers.
What is the technical difference between the three?
Can a PN user request a change to suit their usage?
15 REPLIES 15
Pettitto
Fixes: 5
Re: Which DLM profile do PN provision FTTC lines on?
Hi AndyH,
By default we opt for the 'Standard' option. We can place a modify order for the other two options you have mentioned by request.
Standard and Speed are pretty close together to be honest. Stable will bring the speed down more if the connection becomes unstable.
jamesanstee
How do we request this modify order as i know im on standard but would like to speed profile.
Pettitto
Fixes: 5
You can request this by raising a ticket at http://contactus.plus.net
w23
Fixes: 4
Why do BT Wholesale use a conflicting set of terms for the DLM profiles?
Dynamic Line management (DLM) to extend coverage and stability, giving more control over the applications WBC FTTC Customers and Reseller Customers can sell with tailored profiles such as Standard, Stable or Superstable
Source: http://br0kent3l3ph0n3.files.wordpress.com/2012/11/bt-wbc-fttc-product-iss-4-5-1-11-3.pdf
Are these ('Standard', 'Stable', 'Superstable') the same thing as the OR profiles ('Speed', 'Standard', 'Stable')
Since Plusnet use WBC FTTC (I presume) wouldn't they be applying those profiles ('Standard', 'Stable', 'Superstable') rather than the OR profiles?
Or am I just getting confused? Undecided
Call me 'w23'
Pettitto
Fixes: 5
You're correct. For some reason Openreach and BT Wholesale give them different names but they are exactly the same products!
We know which are which so we can easily find the right one and place a modify order for you.
Oldjim
Resting Legend
Fixes: 63
Chris,
You need to reply to this thread and train some agents http://forums.thinkbroadband.com/plusnet/f/4282360-can-plusnet-change-fttc-dlm-settings.html
w23
Fixes: 4
Just to clarify fully please, is Plusnet (home rather than business) FTTC provisioned on OR 'Standard' (BTw 'Stable') or BTw 'Standard' (OR 'Speed') or ??  Huh
Call me 'w23'
jamesanstee
Trying to raise a ticket to request the profile modify order for speed its just taking me back to the same page on a loop so cannot raise a ticket maybe the ticket system could be made a bit more user friendly.
Pettitto
Fixes: 5
@Oldjim - Thanks for linking me to that, I'll address that.
@w23 - We place orders labelled on BT Wholesale as 'Standard' which is equivalent to 'Speed' on BT Openreach's documentation.
@jamesanstee - Not sure why it;s doing that, can you try clearing your Cache and Cookies and trying again please?
jamesanstee
Modify order request submitted ticket 77214038
Pettitto
Fixes: 5
Just to clarify:
BT Wholesale 'Standard' = Openreach 'Speed'
BT Wholesale 'Stable' = Openreach 'Standard'
BT Wholesale 'Super Stable' = Openreach 'Stable'
I hope that makes sense!
deathtrap
My Question was already answered
goldenfibre
Seasoned Pro
Fixes: 12
Quote from: Chris
Just to clarify:
pretty daft by bt wholesale as they always making too complication for us to get confusion by this.
RCrozier
Would any of these options decrease my latency? Cheesy
