Where has my speed gone?
- Where has my speed gone?
Re: Where has my speed gone?
23-10-2007 6:58 PM
I have ordered another filter just in case my #2 was also a bit iffy. I will then run the test again and report back.
25-10-2007 4:26 PM
OK, new filter and nothing else connected into main socket.
Speed test shows:
IP profile for your line is - 1500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 736 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 471 kbps
I am not a happy bunny
Could you please look into this.
Thanks,
Chris.
25-10-2007 4:35 PM
If you could possibly visit http://faults.plus.net and raise a fault, we'll then be able to investigate and raise to BT for you.
25-10-2007 4:42 PM
25-10-2007 5:57 PM
25-10-2007 6:04 PM
All done, so we'll wait and see what happens.
25-10-2007 8:02 PM
Broadband Fault Checker - Connection checks [ Completed ]
Dear *********,
The results of our tests show no fault with your broadband connection. Completed speed tests show that your connection speed is: none found ( ???)
According to BT, this speed is within the limits of acceptable performance for broadband service.
Kind Regards,
Customer Support
So what the hell does this mean?
I am not paying £22.49 a month for a service that is no better than dial up!
Over to you.
25-10-2007 8:07 PM
That message is a horrible error in the text from the automated faults checker. We are going to get that sorted although it should have been done long ago.
<note to self> chase this in the morning </note>
Basically ignore it for now and one of the faults guys will get back to you.
Apologies for the rubbish automated response.
25-10-2007 9:05 PM
Further to what Mark has said, we will be getting that text changed, however all it means is that there are no BT Speedtest results showing in the database.
If you could add a comment to the ticket advising of your latest speedtest results we'll take this further for you.
26-10-2007 8:34 AM
Quote from: PJ
Quote from: Helmetfire IP profile for your line is - 1500 kbps
Mand, are you or another staffer able to use the above to progress the fault?
I am now, and have done so, but when posting last night I wasn't in the office and didn't have access to our internal systems.
Chris,
Your fault is now back with our faults team for further testing.
26-10-2007 8:56 AM
I've tried running some testsd on your line.
Could you possibly connect again for me so that I can get some test results?
26-10-2007 10:43 PM
28-10-2007 7:20 PM
I hope your speeds can be sorted out mine could not. I think someone from openreach may have played with my line while fixing someone elses and as a result reduced my ability of a constant sync speed.
A
29-10-2007 9:25 AM
Bring on FTTH
29-10-2007 2:17 PM
A
