Where has my speed gone?
- Re: Where has my speed gone?
22-10-2007 3:11 PM
IP profile for your line is - 2500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 3008 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2259 kbps
I'm in Hastings, East Sussx.
Is there anything going on with the network that could cause this slowdown?
Any help/advice welcome.
Thanks,
Chris.
22-10-2007 3:38 PM
It looks like your sync speed has dropped (the 3008 figure in your speedtest) and as a result so has your profile (the 2500 figure).
Have you added anything to your line recently which could be causing interference? Have you got filters on all connected devices?
If no to the above it may be worth replacing your filters and plugging your router into the master socket if it's not already as this should give you optimum performance.
22-10-2007 3:45 PM
Will try new filter.
Thanks,
Chris.
22-10-2007 7:00 PM
I know its nothing this end and the router is syncing to the exchange at 7866kbps and 448kbps.
Would be nice to get my old speeds back again as its does sometimes make a difference when downloading files.
Regards
Howard (Metronet)
23-10-2007 8:23 AM
Could you run a BT Speedtest for me please as your issue looks a little different?
It may be that your profile changed recently and we haven't yet received the update but according to our records you've got an IP profile of 7000.
23-10-2007 8:53 AM
Looking into this a bit more, it looks like your speeds dropped from the 13th till the 22nd. They're back up again, and if you reboot hopefully you'll see a return to faster speeds.
23-10-2007 10:33 AM
Thank you for looking into this for me. I have rebooted my router just now and the router itself is reporting 8128 down and 448 up.
BT speedtester report the following:
The Performance Tester is now testing Broadband connection. Your configured download throughput speed for this service is 3000 k
IP profile for your line is - 3000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2815 kbps
(This was still connected to metronet and not via the BT login as the BT site told me to use my ISP and not the BT connection).
Also tried another online speedtester www.speedtest.bbmax.co.uk and it roughly agrees with BT showing 2924/304.
Regards
Rockradio
23-10-2007 10:38 AM
I'll raise a fault with BT.
23-10-2007 10:41 AM
23-10-2007 11:03 AM
Actuate & Woosh show 7150Kbps.
I've raised the fault, rockradio. You should see the ticket on your account.
23-10-2007 11:16 AM
Regards
Rockradio
23-10-2007 3:21 PM
DSL connection rate: 448 kbps(UP-STREAM) 1888 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1247 kbps
23-10-2007 3:28 PM
The problem you have is your downstream synchronisation speed. this has dropped below 2000Kbps.
It would be worthwhile changing your filters and ensuring that you are connecting into your master socket via a filter and see if this improves the sync speed.
23-10-2007 3:30 PM
23-10-2007 6:19 PM
Quote from: Helmetfire DSL connection rate: 448 kbps(UP-STREAM) 1888 kbps(DOWN-STREAM)
Your Fault Threshold Rate is 2278kbps. We can raise a fault if your DOWN-STREAM regularly drops below this but you'd need to replicate the problem from your master telephone socket with no other telephony devices connected to your line at the time.
