Where has all the fibre gone?
- Where has all the fibre gone?
16-02-2012 9:33 PM
However, http://maps.thinkbroadband.com/#!lat=51.6126641552618&lng=-0.21788065665590217&zoom=14&type=roadmap&... shows that I'm not just without fibre, but I that seem to be on a special low speed part of the exchange.
The red blob is the exchange.
I'm in the yellow area.
Re: Where has all the fibre gone?
17-02-2012 12:32 AM
So don't feel so bad :
17-02-2012 10:34 AM
Your sync speed looks rather low for your attenuation, I'd have expected much more. Not sure what kit you're using or how it's set up.
Jojo
17-02-2012 11:25 AM
i think they just chucked some paint on the map for the colours
17-02-2012 12:21 PM
Quote from: Joanne Your sync speed looks rather low for your attenuation, I'd have expected much more. Not sure what kit you're using or how it's set up.
Jojo
My (Netgear) router is plugged directly into the test socket part of the BT NTE5 socket.
BT have been round in the past and their speeds match mine.
It's just a rotten line.
17-02-2012 1:24 PM
Quote from: niko ignore that map ,its showing 3 villages in my area as able to get 16mbps when the exchanges havent even got adsl2 never mind cable ,you cant get over 2mbps in all 3 of them
But do they have LLU options?
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
17-02-2012 1:26 PM
17-02-2012 1:49 PM
What Netgear is it?
Jojo
17-02-2012 2:05 PM
PC connections are made wirelessly.
17-02-2012 2:14 PM
Customer and Forum Moderator.
17-02-2012 2:26 PM
I don't think it's right, as my cabinet and loads of others don't appear to have a power supply!
17-02-2012 2:45 PM
21CN for my exchange says July 2012
17-02-2012 3:34 PM
Quote from: A A Netgear DG834G (version 5, unfortunately), so I can't push the noise margin down.
The SNR is currently 5dB so that's not the issue. Have you ever tried another router?
Jojo
17-02-2012 4:39 PM
They've all given roughly the same speed (within 0.5Mbps of each other).
The SNR varies quite a lot, at night it may go down to 3dB.
17-02-2012 5:05 PM
