When does the fibre router arrive?
- When does the fibre router arrive?
11-02-2012 9:53 AM
Re: When does the fibre router arrive?
11-02-2012 12:02 PM
11-02-2012 12:25 PM
I would expect yours to turn up Mon/Tues.
11-02-2012 12:49 PM
11-02-2012 12:52 PM
I've looked into this for you. Your router should be with you within 3 - 5 working days. I hope this helps
13-02-2012 11:20 AM
I don't know where the 3-5 working days comes from as it was posted the day before.
I will probably buy myself a different router because the Netgear seems to have some (minor) bugs.
13-02-2012 11:44 AM
Quote from: mapletree I will probably buy myself a different router because the Netgear seems to have some (minor) bugs.
Such as? I haven't come across anything that affected normal usage.
13-02-2012 1:26 PM
13-02-2012 5:11 PM
13-02-2012 6:17 PM
13-02-2012 9:06 PM
14-02-2012 8:41 AM
14-02-2012 10:52 AM
14-02-2012 2:34 PM
Have you tried using reservations without changing the DHCP range?
Jojo
14-02-2012 3:55 PM
Mind you, having seen complaints about the wireless setup in another thread, not upgrading might be a good thing!
Graham
