Whats the difference
Fixes: 9
What is the difference between essential fibre (38MB) and unlimited fibre  (76MB) ?
Fixes: 4
Re: Whats the difference
£4
pengbo
and infinite downloads instead of 40GB per month. (well it's not strictly infinite more like 24 TB)
koan1011
Is the 24TB limit a T&C limit or a bottle neck limit (by that I mean if you could run a full speed for a month you would only be able to download 24TB)?
Fixes: 348
There is no t&c limit, but 24TB is probably the theoretical maximum you can achieve if you have the full 80mbit line Smiley
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
pengbo
Exactly devorak.  It's a pretty simple calc  Cheesy
Would live to see the home set-up that could handle that kind of download lol.
Edit: Actually scrub that you wouldn't need to store it.  I keep forgetting streaming HD is now actually viable  Cheesy
