Whats setting is changed by PN to uncap upstream speed?
- Whats setting is changed by PN to uncap upstream s...
- « Previous
- 1
- 2
- Next »
Re: Whats setting is changed by PN to uncap upstream speed?
20-01-2014 2:42 PM
which line drops to zero - if it is the noise margin then that is the problem and capping it may help
In my case it was even worse as the line would resync with an upstream speed as low as 192kbps with a 6dB noise margin
It would help if you posted the router stats - noise margin, speeds and attenuation both up and down
Message 16 of 20
(220 Views)
20-01-2014 2:50 PM
Look at reply 2 for the last router stats taken yesterday evening and BT Profile check.
I think all of them. speed and SN up and down.
I get this, see BT line check
I usually power the PC off when not used, potentially I could have to wait a few days until the error occured.
Thanks for your comments
Quote which line drops to zero
Quote In my case it was even worse as the line would resync with an upstream speed as low as 192kbps with a 6dB noise margin
Quote It would help if you posted the router stats - noise margin, speeds and attenuation both up and down
Message 17 of 20
(220 Views)
20-01-2014 2:54 PM
All of them dropping to zero including speed indicates a problem with the router perhaps unless that only happens when the line loses synch and takes a while to resync
The question is what happens to the noise margin when the phone is used and it holds sync
Message 18 of 20
(220 Views)
20-01-2014 3:12 PM
I would say I've not paid much attention to router stats, the router is fine as I have the same problems with my old Thomson 585 v7 and different filters.
I will have to set up router stats and see what happens.
Thanks again for your time.
Message 19 of 20
(220 Views)
20-01-2014 3:22 PM
Quote from: Oldjim All of them dropping to zero including speed indicates a problem with the router perhaps unless that only happens when the line loses synch and takes a while to resync
Is it not also possible that it's only that RoterStats failed to get the information from the router and in fact there's nothing wrong with the connection?
Message 20 of 20
(220 Views)
- « Previous
- 1
- 2
- Next »
