Whatever happened to ADSL2+?
- Whatever happened to ADSL2+?
26-09-2011 9:44 AM
Or are only certain account types eligible. Since most of the posts on the subject appear 2 years old I figure they're out of date?
Re: Whatever happened to ADSL2+?
26-09-2011 1:13 PM
26-09-2011 1:48 PM
When your exchange gets upgraded to 21CN (ADSL1 & ADSL2+) we don't automatically upgrade you, although we are currently migrating our customers onto it bit by bit.If you wish I can place the order for you today, which should complete in 5-7 working days. It's not just for new customers, but new customers are automatically provisioned onto 21CN if it is available at the exchange. Depending on the loop loss or estimated speed we will decide whether it would go on ADSL1 (up to 8Mbps) or ADSL2+ (up to 20Mbps)
Jojo
26-09-2011 1:54 PM
Unfortunately work is still stuck with 3.5M and 50dB so I figure it'd probably make things worse?
26-09-2011 2:08 PM
Can you upgrade me?
26-09-2011 2:13 PM
Is this forum account your home one?
Jojo
26-09-2011 2:35 PM
I'll take a look into that for you.
Jojo
26-09-2011 3:28 PM
I've placed an order to upgrade to ADSL2+ this should complete in 5-7 working days.
Jojo
26-09-2011 3:33 PM
Regarding the work account (coaxial): Other than moving to a new factory is there anyway to improve on the 52dB? We're on the edge of town, google maps puts us 2.7 miles from the exchange?
26-09-2011 3:39 PM
I could give your SNR a reset. However, this isn't that high at the moment, only 10dB. What router do you use? Others have found that routers such as the HH2 work better on longer lines. Try optimising your internal wiring. Make sure you aren't using extensions before your router.
Jojo
26-09-2011 3:47 PM
26-09-2011 3:54 PM
Give me a nudge in the next day or two and I'll make sure the order is progressing ok, bearing in mind something seemed to go amiss last time, it's worth checking.
Jojo
26-09-2011 4:24 PM
Quote from: Joanne Hi oliverb,
Jojo
Draytek Vigor 2800VG currently, though I also have a couple of old Billions and a MK1 homehub lying around as spares/loaners. Switching is a PITA because there's no quick way to set the DHCP table.
Its probably not SNR, that was reset some time ago after we discovered a PC with a busted mains filter about 2 years back. I say we, but it took BT openreach coming round with a detector to find it, after which I shoved it on our own tester and the noise stood out like a sore thumb.
I've been down the wiring optimisation route, I've fitted a faceplate splitter. It did help, I think that got us from 2.5M to 3.5M.
26-09-2011 4:36 PM
Well, if there's anything I can help you with, don't hesitate to give me a nudge.
Jojo
02-10-2011 10:40 PM
Quote from: Joanne Hi MeMeMe,
Jojo
Hi Jojo, just giving you a nudge to see if the order is progressing.
