What would cause TG582n to not connect with time server(s) (SOLVED)
- Re: What would cause TG582n to not connect with ti...
14-12-2013 11:52 AM
As per title
What would cause TG582n to not connect with time server(s) and default back to 01/01/2000
I have tried 3 different servers by both the routers GUI and telnet and they do not connect
Telnet example:
sntp add name=2.uk.pool.ntp.org
saveall
all 3 show in the sntp list as unable to connect
List of the 3 time servers tried to date
P.S I do have a support ticket for a new router due to errors causing drop in speed,
so just more curious and understanding as to what could cause the above issue
I have also set the Dns servers by telnet to open Dns and makes no difference
Telnet example:
saveall
- ntp.plus.net
- ntp2b.mcc.ac.uk
- 2.uk.pool.uk.org
Message 1 of 6
(4,060 Views)
5 REPLIES 5
Re: What would cause TG582n to not connect with time server(s)
14-12-2013 12:01 PM
See: https://community.plus.net/forum/index.php/topic,113730.0.html
If the Plusnet Broadband Firewall set to "high", then ntp won't work.
Message 2 of 6
(856 Views)
14-12-2013 12:32 PM
I can not see a Firewall (high) setting, and mine is currently set to basic
Here are the router stats
{admin}=>xdsl info expand=enabled
Physical Layer Statistics:
Modem state: up
Up time (Days hh:mm:ss): 0 days, 2:10:35
xDSL Standard: ITU-T G.992.5
xDSL Annex: Annex A
Channel Mode: Interleaved
Number of reset: 0
Chipset Vendor info (G.994.1): Local Remote
Country code: B500 B500
Specific: 0000 0510
System Vendor info (showtime): Local Remote
Country code: 0F00 0000
Specific: 3C61 0000
Bearers generic info DS US
Payload rate [Kbps]: 8371 448
Attenuation [dB]: 47.5 27.2
Margins [dB]: 6.0 18.1
Output power [dBm]: 20.4 11.8
Number of bearers: 1
Bearer 0 DS US
INP [DMT symbols]: 0.00 0.00
Delay [ms]: 0.24 1.00
Depth []: 1 0.00
R: 0 0
G.997.1 Statistics (Current):
Failures:
Line failures Near end
Loss of signal (LOS): 0
Loss of frame (LOF): 0
Loss of power (LPR): 0
Performance monitoring:
Line PM: Near end
Error second (ES): 823
Channel PM: Near end Far end
Bearer 0:
Code Violation (CV): 3425 4
FEC: 0 0
ATM data path PM: Near end Far end
Bearer 0:
HEC violation count (HEC): 855 N/A
G.997.1 Statistics (last 15 minutes):
Failures:
Line PM: Near end
Error second (ES): 102
Bearer 0:
FEC: 0 0
Bearer 0:
G.997.1 Statistics (last 24 hours):
Failures:
Line PM: Near end
Bearer 0:
FEC: 0 0
Bearer 0:
{admin}=>
Message 3 of 6
(856 Views)
14-12-2013 12:36 PM
I think you'll find npr ejs is referring to the web based firewall.
https://portal.plus.net/index_nlp.html
Don't forget to disconnect/reconnect in your router for settings to take effect!
oops, sorry ejs.
oops, sorry ejs.
Message 4 of 6
(856 Views)
14-12-2013 12:37 PM
There isn't such a thing as Basic - have you looked here https://portal.plus.net/my.html?action=firewall
Message 5 of 6
(856 Views)
14-12-2013 12:55 PM
Thanks ejs
I got mixed up between the router Firewall and the web based firewall,
With thanks to 30FTTC06 for setting that straight
Thanks Oldjim
Sorry, my bad , for causing any confusion, I did mean Standard in the router GUI and not basic as per earlier screenshot
However that said, the Firewall was set to high, now amended and updated via the web Firewall, will disconnect and reconnect after I send this post
[Edit]
Thank you guys it has worked a charm
Issue with the time is now SOLVED albeit with the exception of lower security protocols
Thanks Oldjim
[Edit]
Message 6 of 6
(856 Views)
