What type of cable connects between the BT modem and the plusnet router
- Re: What type of cable connects between the BT mod...
18-01-2014 9:11 AM
I'm planing to replace the supplied cable with a 1m STP cat6 cable. to prevent possible inference due to power supplies. Just need an idea of what cables in use.
Message 1 of 5
(845 Views)
4 REPLIES 4
Re: What type of cable connects between the BT modem and the plusnet router
18-01-2014 9:14 AM
The cable that's used to connect the Openreach Modem to your Plusnet router is an Ethernet Cable.
I hope that helps.
I hope that helps.
Message 2 of 5
(562 Views)
18-01-2014 9:17 AM
hi Chris, i just wanted to know if it was a straight through/ rollover etc. saves me buying the wrong cable
jim:quote
jim:quote
Message 3 of 5
(562 Views)
18-01-2014 9:29 AM
I would say a standard straight through from memory - if you have the cable that came with it just see if it has a small band with a "x" on it for crossover.
I'm using a straight through for my BT to TP-Link.
Message 4 of 5
(562 Views)
18-01-2014 9:30 AM
It's a normally wired (ie not crossover) cable but you're wasting your money!
Changing this cable will have zero affect on your broadband performance.
Message 5 of 5
(562 Views)
