What to do about continual line quality problems?
- What to do about continual line quality problems?
16-01-2011 8:30 PM
I've been a Plusnet customer for getting on for a year now and am just about at my wits end.
Not Plusnet's fault, I should add but the line itself.
Our problems started back in the spring (2010). Tree growth rubbed through the last section of line leading to our house and the cable (plus 3 telegraph poles) needed to be replaced. Eventually BTW gout this done but we still had issues. BTW My main reason for having a land line is for my broadband which is essential to my lifestyle, we did also get audible noise on the phone.
Several months later BT sent round a special investigations team and a few days later the fault was fixed. They identified 4 faults on our line, including one on the new piece of cable where it had been pinched when installed.
All was OK until the extreme cold in December and we now have unreliable connections and intermittent noise on the phone AGAIN.
BT have had a look but say they can do nothing unless they see the fault. Obviously I think they should send back in the team that identified the previous faults as they have test gear that will identify the fault. I've spoken to the BT engineers who say it will be a high resistance connection but without the special test kit it isn't possible for the ordinary engineers to find the fault.
In the meantime, every morning the connection is down and its up and down during the day also :((
I'm so frustrated and no one at Plusnet support seems to be able to help.
What can I do?
BTW I have 3 routers, so not a router problem. BT replace their ADSL v1 faceplate every time they come in so its not that at fault. We have no phone extensions, just the master where our one phone and the router is connected.
Any one here able to assist?
Regards
Frustrated
Re: What to do about continual line quality problems?
16-01-2011 8:41 PM
16-01-2011 9:51 PM
16-01-2011 9:58 PM
17-01-2011 9:57 AM
Can you identify a pattern to when the noise occurs? Does it happen when it rains, for example?
17-01-2011 10:36 AM
We are 7km from the exchange and its all overhead cabling that goes through trees, gets eaten by squirrels etc.
BTW the DSL connection tends not to loose sync, but the data error rate is so high that the PPoA connection drops and then won't re-establish for ages. I see this as very, very slow response at times then the connection drops.
When it was all working well the connection was surprisingly fast given the distance from the exchange. The special investigations engineer tested the line at 2mbps and said that it was error free at that speed once the original faults were fixed. Now I'm lucky to get 900kbps with a connection established at about 1300kbps - although stability is more important to me than speed.
Its really a very poor show.
Regards
17-01-2011 11:12 AM
17-01-2011 5:24 PM
your line certainly doesn't look stable. The first thing you need to do is raise a fault. We can then chase it form there.
Jojo
17-01-2011 5:40 PM
17-01-2011 6:00 PM
tx
