What the ? - line drops when I switch on phone.
As soon as I switch on the phone (dect phone - button equivalent of lifting handset) The broadband connection drops.
I've tried 3 microfilters - all the same.
There is also noise on the phone line. We had a call about the noise with BT a few weeks ago, but it was closed, because the noise vanished of its own accord.
Any ideas? (PS - we don't have a master socket with test socket)
Re: What the ? - line drops when I switch on phone.
Does the noise on the line still exist when you disconnect your ADSL router from it;s phone socket? If yes then all the filters you have tried are not of good enough quality to filter out the ADSL signalling. Many 'cheap' filters have problems with DECT phones. I recommend XF-1e Professional ADSL Microfilter.
If the noise still exists with router disconnected then raise a voice fault but don't mention ADSL.
pierre_pierre
is there any noise with the broadband disconnected/
there are some reports that some DECT phones need two filters one after the other.
my set up is like yours, no master Socket, dect master near to router, plus two dect extensions.  plus two other normal phones but I dont have any trouble.
the next thing to try is get a standard phone, plug that in, take out the dec and see if that causes the line to drop
Peter V beat me to it
Standard phone? Whats on of them then  Grin
Thanks for the suggestions - will give them a try.
PS - one thing to be aware of though - This is unlikely to be a fundamental problem with the line filters. I have four identical, (3 have been unused). The one in use has been fine for years - but now I have the problem. The fact that none of the other 3 fixes it, suggests it is not the filter at fault.
James
Do you get noise on your line?
It's more likely to be a voice line fault than a broadband one.
pierre_pierre
Quote from: tonycollinet
Its one of those things you should have, in a power loss situation a Dect phone will not work, A standard phone will, it takes its power from BT. so you can then phone the emmergency services
reserved
http://www.shop.bt.com/products/bt-decor-1100-white-corded-phone-4CYK.html?refs=45250000
Argos do them a lot cheaper but the link is too long to post.
As pierre_pierre says, essential for use in a power cut !
Can you just humour me and try double filtering the DECT phone?
Ie:  socket -> filter -> filter -> DECT Phone
Make sure you plug the ADSL router into the filter that is directly plugged into the wall socket.
B.
You didn't say if the noise was there with the router disconnected?
Denzil
Quote from: reserved
Try like this!
reserved
Thanks Denzil, I'm not that clever  Wink
scootie
use the code <a href="http://www.echoecho.com/htmllinks01.htm">here</a> or a website that makes tiny url's for you
Fixes: 62
or even easier this code [url=www.bbc.co.uk] The BBC [/url] will give this The BBC
reserved
Thanks both, I'll try and remember for next time!!!!  Cheesy
