What the ? - line drops when I switch on phone.
- Re: What the ? - line drops when I switch on phone...
30-09-2009 9:07 PM
I've tried 3 microfilters - all the same.
There is also noise on the phone line. We had a call about the noise with BT a few weeks ago, but it was closed, because the noise vanished of its own accord.
Any ideas? (PS - we don't have a master socket with test socket)
30-09-2009 9:42 PM
If the noise still exists with router disconnected then raise a voice fault but don't mention ADSL.
30-09-2009 9:46 PM
there are some reports that some DECT phones need two filters one after the other.
my set up is like yours, no master Socket, dect master near to router, plus two dect extensions. plus two other normal phones but I dont have any trouble.
the next thing to try is get a standard phone, plug that in, take out the dec and see if that causes the line to drop
Peter V beat me to it
30-09-2009 10:42 PM
Thanks for the suggestions - will give them a try.
PS - one thing to be aware of though - This is unlikely to be a fundamental problem with the line filters. I have four identical, (3 have been unused). The one in use has been fine for years - but now I have the problem. The fact that none of the other 3 fixes it, suggests it is not the filter at fault.
30-09-2009 11:25 PM
It's more likely to be a voice line fault than a broadband one.
01-10-2009 7:59 AM
Quote from: tonycollinet Standard phone? Whats on of them then
Its one of those things you should have, in a power loss situation a Dect phone will not work, A standard phone will, it takes its power from BT. so you can then phone the emmergency services
01-10-2009 9:21 AM
http://www.shop.bt.com/products/bt-decor-1100-white-corded-phone-4CYK.html?refs=45250000
Argos do them a lot cheaper but the link is too long to post.
As pierre_pierre says, essential for use in a power cut !
01-10-2009 9:46 AM
Ie: socket -> filter -> filter -> DECT Phone
Make sure you plug the ADSL router into the filter that is directly plugged into the wall socket.
B.
01-10-2009 7:05 PM
01-10-2009 10:51 PM
02-10-2009 10:32 AM
02-10-2009 10:39 AM
02-10-2009 11:01 AM
02-10-2009 11:12 AM
