What's the point?
- What's the point?
- « Previous
- Next »
Re: What's the point?
08-01-2010 2:28 PM
08-01-2010 3:16 PM
08-01-2010 3:20 PM
08-01-2010 3:31 PM
But considering that I sync at 8128 on ADSL, how do they decide this 'up to 9mb' figure represents what my experience will be like? I know OFCOM say a line speed check must be given, but if it's so conservative as to be unrealistic, how would it help a 'normal' user evaluate what package to choose?
08-01-2010 3:38 PM
08-01-2010 5:47 PM
08-01-2010 6:38 PM
Plusnet: This user seems to be unhappy with the idea of not getting the estimated speeds - please could you restrict his current speeds to the typical rate for someone syncing at 7M.
08-01-2010 7:34 PM
Yet again you miss the point. I'm not unhappy with my current setup. I'm unhappy with being told that when I upgrade to 21CN my speed will only increase by a small amount when in all likelihood it will be far more. I currently have a package where I get line speed for everything but peer to peer up to 4pm which only then becomes peak. At the moment the majority of my downloads are conducted through download sites, which, under the new 21CN, start to get restricted from 8am, and by 9 will be at a lower rate than I currently get on ADSL. In reality, I'd only get to see the ADSL2 speed increase between 12 and 8 in the morning. So, perhaps you can understand why I'd be a little concerned to lose my extended off-peak and rely on downloading those files I need during the night instead, if my actual speed wasn't going to at least double to make up for it.
10-01-2010 2:01 AM
have a look at your modems modulation type
ADSL2 Auto (g992.3)only uses 256bin = 9meg ish (it did last time i looked on my modem)
ADSL2+ (g992.5) 512bin = a lot faster
bet thats all that needs doing for a better sync speed, you may need BT/Plus net to set SNRM to 6db etc
then BT/ Plus net need to remove any data flow limits / banding pish etc., then you'll go like a bat out of hell
hth
10-01-2010 9:16 AM
11-01-2010 3:37 PM
Think about it, on my current package from 4pm-midnight my ADSL download speeds are equal to or faster than ADSL2 download speeds. Having double the headline speed but half the actual speed doesn't appeal to me really 😕
11-01-2010 11:33 PM
- « Previous
- Next »
