What's the point?
esseff
What's the point?
I live a half a mile from the exchange. I'm currently on ADSL Max 8MB and sync at 8128.
My exchange has finally become ADSL2+ enabled, so I thought, well, if I get the maximum speed now, then surely I should at least double my current speed by upgrading.
So, can anyone explain why, after touting this as the next generation ADSL broadband connection, I'll hardly see any increase?
Fixes: 10
Re: What's the point?
What makes you think you've been upgraded? All your other posts seem to indicate you are still on ADSL1.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
esseff
Quote from: esseff
Not sure how this statement is confusing you.
I'm asking what's the point in upgrading if, even with my excellent line stats, I still wont get anything like the claimed 'upto 24MB'.
Fixes: 70
Quote from: esseff
Why do you say you'll hardly see any increase as others have?
You appear to have very good stats.
Customer and Forum Moderator.
pierre_pierre
and some got a decrease  Embarrassed, Stil I dont care I am on value so cant get more than 8 M,  My schange date is 1 to 28 Feb  Cheesy
esseff
The screenshot I posted was taken from information supplied by BT Wholesale. It clearly shows an estimated speed of 9. I currently get 7. It's meant to be upto 24. What else should I infer from it?
Fixes: 10
Why are you not complaining that it says you will only get 7Mb when you are actually getting 8Mb?
You should regard the ADSL2+ estimate in the same light!
Edit: Did you put your postcode or the phone number in to the checker?
Quote from: esseff
Yes.
But rather than waste effort on hypotheticals and the limitations of BT's estimates, please post some REAL stats from your router and we can give you a much more REALISTIC estimate.  Wink
(sync speeds, attenuation and noise margin should be included)
Fixes: 10
Or you can do it yourself: http://www.kitz.co.uk/adsl/max_speed_calc.php
esseff
Quote from: jelv
Why should I? Huh
I sync at 8128 - the maximum I can. I get 7150 - the maximum available.
Therefore, ADSL2+ should give me the same kind of increase - at least double if not more. I hardly think 2MB is ADSL2+. Do you?
Quote from: jelv
Would it even work without one?
Here's my stats as requested:
esseff
Quote from: jelv
That shows a much better figure - so how do I know what to believe?
Fixes: 70
The ultimate test of course is an actual ADSL2+ connection but the BT test result is, by it's own admission a very conservative figure.
Important: The above figures are obtained from the BTw database, which is often conservative.
Fixes: 10
I was asking which you put in - if you put in the postcode it tends to be more inaccurate than if you put in your telephone number.
esseff
I see.
Same result.
adie:quote
esseff
Quote from: Strat
Fair enough. But there's conservative and conservative. Kitz says my Ip profile should increase from 7150 to 19000!
