What's the point?
esseff
What's the point?
I live a half a mile from the exchange. I'm currently on ADSL Max 8MB and sync at 8128.
My exchange has finally become ADSL2+ enabled, so I thought, well, if I get the maximum speed now, then surely I should at least double my current speed by upgrading.
So, can anyone explain why, after touting this as the next generation ADSL broadband connection, I'll hardly see any increase?
41 REPLIES 41
jelv
Fixes: 10
Re: What's the point?
What makes you think you've been upgraded? All your other posts seem to indicate you are still on ADSL1.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
esseff
Quote from: esseff
Not sure how this statement is confusing you.
I'm asking what's the point in upgrading if, even with my excellent line stats, I still wont get anything like the claimed 'upto 24MB'.
Strat
Fixes: 565
Quote from: esseff
Why do you say you'll hardly see any increase as others have?
You appear to have very good stats.
pierre_pierre
and some got a decrease  :-[, Stil I dont care I am on value so cant get more than 8 M,  My schange date is 1 to 28 Feb  Cheesy
esseff
The screenshot I posted was taken from information supplied by BT Wholesale. It clearly shows an estimated speed of 9. I currently get 7. It's meant to be upto 24. What else should I infer from it?
jelv
Fixes: 10
Why are you not complaining that it says you will only get 7Mb when you are actually getting 8Mb?
You should regard the ADSL2+ estimate in the same light!
Edit: Did you put your postcode or the phone number in to the checker?
HPsauce
Quote from: esseff
Yes.
But rather than waste effort on hypotheticals and the limitations of BT's estimates, please post some REAL stats from your router and we can give you a much more REALISTIC estimate.  Wink
(sync speeds, attenuation and noise margin should be included)
jelv
Fixes: 10
Or you can do it yourself: http://www.kitz.co.uk/adsl/max_speed_calc.php
esseff
Quote from: jelv
Why should I? Huh
I sync at 8128 - the maximum I can. I get 7150 - the maximum available.
Therefore, ADSL2+ should give me the same kind of increase - at least double if not more. I hardly think 2MB is ADSL2+. Do you?
Quote from: jelv
Would it even work without one?
Here's my stats as requested:
esseff
Quote from: jelv
That shows a much better figure - so how do I know what to believe?
Strat
Fixes: 565
The ultimate test of course is an actual ADSL2+ connection but the BT test result is, by it's own admission a very conservative figure.
Important: The above figures are obtained from the BTw database, which is often conservative.
jelv
Fixes: 10
I was asking which you put in - if you put in the postcode it tends to be more inaccurate than if you put in your telephone number.
esseff
I see.
Same result.
adie:quote
esseff
Quote from: Strat
Fair enough. But there's conservative and conservative. Kitz says my Ip profile should increase from 7150 to 19000!
