What's happening with BT?
- What's happening with BT?
03-02-2008 10:35 AM
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 1750 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2272 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1343 kbps
which is pretty poor when I used to be able to connect at over 3000kbps.
I've been rebooting the router around once a day, but never seen a better speed. How long should this take (seeing as the training period is only supposed to last 10 days)? I am getting the distinct feeling that I may end up with the same speed at the end of the training period as at the beginning...
Re: Target SNR
03-02-2008 10:44 AM
Not all SNR target changes are successful as changing the SNR does not fix whatever caused it to go higher in the first place. If the cause is still there, the exchange will up the target SNR again automatically, just like it did previously.
If you are still syncing at 15dB then either the target SNR has not been changed (happens quote often even when BT say they have changed it) or the same fault has caused it to be reset higher again.
Re: Target SNR
03-02-2008 11:06 AM
"As per the call to you today, BT ahve advised to us that they have performed the change requested. At the same time, a 10 day Max retrain period has occured, which has resulted in a slightly slower speed at this time.
As it is within the retain period, service should icnrease as the service settles over the remain 8 day period."
So either once again BT haven't initiated (I know PN have chased them hard), or something else is going on?
06-02-2008 8:03 AM
All very frustrating
Re: What's happening with BT?
06-02-2008 8:13 AM
Sadly the only thing you can really do is be thankful that PN are chasing it for you, and hopeful that BT will pull their fingers out soon.
06-02-2008 8:59 AM
James has been trying to get mine done for a couple of weeks too, the last update on my ticket was last week and James said that BT had ignored the first request and he had submitted it again.
I'm annoyed with this situation - not with PN, but with BT. As far as I'm concerned it was they that created my problem, only they can put it right, and if they don't put it then there doesn't seem to be anything I can do about it...
06-02-2008 9:05 AM
This means that we have to raise it as a fault, when it isn't, it's a configuration change. Their automation then kicks in and runs standard checks on the line which finds no fault, because there isn't one.
It's only when you get someone in diags to actually read the request that something gets done.
06-02-2008 9:19 AM
On the other hand, isn't BT's automated equipment supposed to deal with this to enable our lines to run at the fastest stable speed it can find?
I had been led to believe that following a fault which increased the margin, that after 30 days the automated systems would bring it back down if the line remained stable. In my case, the line has been rock solid, as it was before my problem at the end of November, which I'm still convinced was caused by the actions of BT in the village.
Do we have any other recourse to get the 'problem' fixed?
06-02-2008 10:50 AM
I totally get that you weeen't having a go at us, I was just trying to outline why there is a problem in getting these kind of requests done.
I'm sorry that I have rather neglected your ticket, but I'll run a couple of tests and see where we are with BT.
06-02-2008 12:58 PM
Has Plus Net not pushed for their PR people to become informed since surely someone cares about image these days, or the comms. ombudsman?
06-02-2008 1:06 PM
We do meet with our account managers within BT Wholesale on a periodic basis where we do feed back with any issues that have been affecting us.
We have raised the SNR issue, but it's unlikely that anything is going to happen without a significant rewrite of their faults systems.
06-02-2008 7:19 PM
I have merged two threads on the same subject by the same OP into a single thread.
Jonathan
aka Chilly
07-02-2008 12:52 AM
Quote from: Snarf Apparently my target SNR was changed 3 days ago...
Are you sure it is just the SNR target that has been changed? You are connected at exactly 2272kb/s, which is EXACTLY the 2Mb speed, I suspect you have been put on the fixed 2Mb MaxDSL profile ... this is a guess on my part and is something PN could confirm if you ask them.
SW.
3Mb FTTC
07-02-2008 8:24 AM
07-02-2008 8:25 AM
Godsell, the account is definitely still on Max, you can tell this by the different upload speed and the fact that they have an IP profile assigned, this is not necessary on fixed rate IPStream.
snarf, we've re-raised the fault for you and will chase BT to confirm this.
