What's happened to my latency? Plusnet network is going backwards
- What's happened to my latency? Plusnet network is ...
03-02-2010 11:08 PM
Something happened to my connection today just after 4pm when the minimum latency jumped by about 3ms.
I'm seeing an increase of about 3ms when pinging ntp.plus.net over the times I've always seen.
I also have f8lure running which shows a similar picture (see attached) which shows a similar increase just after 4pm. Between 9:30 and 10 pm I was gateway hopping which explains the other lines on the graph. This shows that the increase is not gateway dependant.
I've checked my router log and there was no reconnection around 4pm.
Re: What's happened to my latency? Plusnet network is going backwards
04-02-2010 10:22 AM
05-02-2010 10:22 AM
05-02-2010 10:40 AM
05-02-2010 10:59 AM
Quote from: jelv It's something either Plusnet or BT have changed.
Are you sure it's not been like this for a while? My monitoring has only been set up since the 29th Jan however every day has exhibited the same symptoms with the exception of last Saturday (connected via various gateways during that time).
I have spoken to Dave about this this and it's something we're looking into as it does seem peculiar. We also set up some additional graphing yesterday afternoon which should hopefully help us see what's going on.
05-02-2010 11:17 AM
Here's all the graphs to date since I activated the monitor (I wonder if TBB would release the raw data to you if I gave permission?).
Friday 29/01:
Saturday 30/01:
Sunday 31/01:
Monday 01/02 (the red bar is where I turned off ping responses in my router for a short time to see how it showed up in the graph) :
Tuesday 02/02:
Wednesday 03/02:
Thursday 04/02:
Friday 05/02 (today so far):
05-02-2010 11:24 AM
05-02-2010 11:40 AM
Would you like me to try disabling pings for about 10 minutes again to see if it induces another change (the router invokes a reconnection when I change this).
Also I'd be happy to try with a different log in to see if that affects things - I'd have to set up another tbb monitor for the changed IP.
