What's happened to my download speed??
- Re: What's happened to my download speed??
23-05-2013 11:35 AM
Speedtest.net is showing my download speed at 4.66 Mb/s when I normally have around 9.6-9.9 Mb/s. I'm on ADSL 2+, so I should expect better. Can this be looked into please?
Message 1 of 6
(1,108 Views)
5 REPLIES 5
23-05-2013 1:05 PM
Looks like it's back up to where it should be. Thanks.
Message 2 of 6
(654 Views)
23-05-2013 4:41 PM
That was a pretty speedy change Glad it sorted itself out for you.
Message 3 of 6
(654 Views)
24-05-2013 10:39 AM
Well, that didn't last long....
Can it be investigated please? Thanks.
Message 4 of 6
(654 Views)
24-05-2013 4:22 PM
I've checked over your connection and can see no obvious issues. Are you connecting over a wired or wireless connection?
If it's wireless I'd suggest trying to change your wireless channel. If you're on a wired connection then it would be worth raising a fault via our troubleshooter at http://faults.plus/net
Message 5 of 6
(654 Views)
24-05-2013 4:23 PM
I always check from my wired connection. It's gone back up to normal, so it appears to be an issue in the mornings.
Message 6 of 6
(654 Views)
