What router to use
numpty
What router to use
Hi
    can anyone recommend an alternative router to the Technicolor that was suplied by Plusnet. This was causing many connection problems so I went back to my old D-Link which works fine but is 7 years old and could conk out at anytime.
        regards Numpty    Huh
Fixes: 127
Re: What router to use
welcome to the forums numpty Smiley
what are you looking for in a router?
Will Moderate For Thanks
If you're happy with the old D-Link, why not look at a newer version of the same?  Amazon is a fairly good place to start.
Call me 'w23'
St3
All Star
stay away from d-link they are cheap and nasty Smiley i use one of these http://www.amazon.co.uk/Netgear-Wireless-N-Router-Modem-connections/dp/B003FS40KU/ref=sr_1_2?ie=UTF8... they are spot on Smiley
numpty
Hi
many thanks for your replies and I will have a look into the one you recommend  and let you know how I got on.
                                Kind regards  Numpty
gswindale
Quote from: ukste20
Just out of interest; how long have you had that router?
We purchased one in early June & had to have it replaced in Nov due to extremely frequent reboots making it unusable.  So far the replacement seems ok but will reserve judgement for a while!
numpty
Had the D-Link 6 years and it is only just starting to creak so I want to replace it before it goes belly up.
Fixes: 36
Sorry to hear that,
What problems were you having, I'm just wondering if you have any feedback for us about it?
Adam
 Adam Walker
numpty
Hi Adam
                my probs started with the suplied Technicolor router after several phone calls was asked to try my old router to se if this solved my conection probs. It did and has been solid for the last 3 or so weeks .The reason I asked for a router that anyone could recommend was the fact that the D-Link is over 6 years old and is not so hot in the wireless department and could fail from old age.
                                              Regards Numpty
Fixes: 9
Are you on 20CN or 21CN?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
dfunked
@ukste20
Funnily enough, I'd advise the same thing to anybody considering Netgear equipment (cheap and nasty)
I've had no end of problems with the 2 netgear routers I've used in the past (supplied by ISPs), and have a dead Netgear 24 port switch in work + another 4 port one that's causing a ridiculous amount of problems considering the miniscule amount of use it has.
Most of the (larger, at least) manufacturers have good and bad models, these days IMHO if you pay a reasonable price you should expect reasonable equipment (check the reviews on any you are considering).
Both D-Link and Netgear get mostly good rewiews for kit in the £50 bracket for example but do check specific models.
What's your budget, different manufacturers would likely be 'better' in different price brackets?
Call me 'w23'
Fixes: 9
Quote from: dfunked
I bought a Netgear DG832v1 in January 2004 - it's still going strong.
I bought a Netgear DS104 10/100 hub (in a blue metal case) some time before that - still going strong. Only issue I have with this is that if you drop it (as I have) it damages the floor.
I have a Netgear WG602 WAP I bought in April 2005 - still going strong.
davidj66
I was sent an open box D-Link router FOC when I joined Plusnet because the then standard router (Voyager??) never arrived. It lasted almost exactly 2 years...then died totally!
I've had a  cheap Buffalo G router for ~ 8 years (which I bought to replace rubbish HORRANGE router) ...still going strong,so you pays your money..............
Are Buffalo still going?
I had one years ago (router only, no modem), still works, Father-in-law has one (model with modem) still going after many years (it's the only wi-fi ADSL modem/router he's ever had).
I have to agree about the Netgear DS104 hub, very solid but not a router.
Call me 'w23'
