What plusnet done now
rookey
Been brill all day my Internet 17mb. Now look what happened Sad
http://www.speedtest.net/my-result/i/716686445
rookey
Re: What plusnet done now
Now no Internet at all grrrr
rookey
This what I get.
Technicolor TG582n
Rookey
Connection could not be established: Authentication failed
Have you tried the usual ? Router straight into the test socket, power off for a couple of minutes then power back on ?
Do you have a normal dialtone without noise on the line etc etc ?
rookey
Done all that bar listening tone as am deaf.
rookey
Got this now
SERVICE INFORMATION
Close Window
You have been connected to this page due to one of the following reasons. You must now shut down your browser and Internet applications before attempting to reconnect.
The BTWholesale access circuit to your Service Provider is currently down.
Your service should be resumed soon.
Or
You are testing your local connection to BT using
'bt_test_user@startup_domain'
Or
You are testing your connection to your Service Provider using 'bt_test_user@domain' where domain is your Service Provider domain name.
Or
Your Service Provider is currently unable to accept your connection request please wait until service is restored or contact your Service Provider for further information.
Or
You have attempted to access an invalid Service Provider domain.
Sad sounds like something is a bit borked at Plusnets end.
Do you know what exchange you're on ?
rookey
Hope is our exchange
I can't see anything on the recent outages page but worth double checking. It could be that nobody has reported the issues as yet.
http://usertools.plus.net/exchanges/mso.php
rookey
I've just done a router wizard reset put in details and it sorted. Strange
Not sure where the hope telephone exchange is but BT are showing a few issues here :
https://www.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=31
Just seen your reply fingers crossed it was just a glitch somewhere.
rookey
Spoke toooo soon...
Am still connected but the speed is like a snail this upgrade to 21CN turn out to be a pain and worse off Sad
Plus net sort it otherwise I am going elsewhere
Plusnet Staff
Plusnet Staff
Fixes: 5
As I've mentioned previously,  your line is in the 10 day training period. We will need to wait for this to complete before looking at a problem with the speeds you're experiencing I'm afraid.
Chris Pettitt
Cloud Environments Engineer
rookey
But I had good speed then it dropped again so this part of the training process
