What is the timeline of seeing performance increase with ADSL2+
- What is the timeline of seeing performance increas...
11-04-2011 8:00 PM
I am now advised I am live on ADSL2+ and have a 10 day training period.
I thought as with most negotiated services it would work it's way down to a stable level, is this an incorrect assumption on my part?
my connection details currently are:
Type Interleave Path
Status SHOWTIME
Downstream
Data rate(Kbps) 5477Kb
Noise Margin 7
Output power(dBm) 124
Attenuation(dB) 36
Upstream
Data rate(Kbps) 444Kb
Noise Margin 18
Output power(dBm) 198
Attenuation(dB) 25
what speeds, should I expect to be seeing?
Darran
Status SHOWTIME
Downstream
Noise Margin 7
Attenuation(dB) 36
Upstream
Noise Margin 18
Attenuation(dB) 25
Darran
Message 1 of 8
(1,148 Views)
7 REPLIES 7
Re: What is the timeline of seeing performance increase with ADSL2+
11-04-2011 8:07 PM
Message 2 of 8
(536 Views)
11-04-2011 8:25 PM
Quote from: darran what speeds, should I expect to be seeing?
In theory, about double.
BUT your stats suggest significant wiring problems, probably with your own internal/extension cables.
Message 3 of 8
(536 Views)
12-04-2011 1:37 PM
HI darran,
I would expect a better sync rate based on your line length. How are you set up? Are you using an extension cable/socket? Can you plug into your test socket so I can test it again?
Jojo
Jojo
Message 4 of 8
(536 Views)
12-04-2011 2:12 PM
I have raised a fault call with BT as looking at my master socket, I have found evidence of corrosion, must have been when we had leak through window when guttering turned into a waterfall last year.
Quite why they put the socket next to a window in the first place I have no idea! (there when we moved in)
anyway, BT are coming armed with that info tomorrow between 1-6pm.
but how will this affect my training period and results attained so far?
Darran
Darran
Message 5 of 8
(536 Views)
12-04-2011 3:52 PM
HI Darran,
Don't worry, just let me know when they've been and I'll run some checks for you.
Jojo
Jojo
Message 6 of 8
(536 Views)
13-04-2011 6:50 PM
OK, BT diagnosed that we had a cable fault somewhere between exchange and home and have moved us to alternate
This is the current status
Downstream
Data rate(Kbps) 14438Kb
Noise Margin 8
Output power(dBm) 115
Attenuation(dB) 28
Upstream
Noise Margin 31
Output power(dBm) 197
Attenuation(dB) 13
Downstream
Noise Margin 8
Attenuation(dB) 28
Upstream
Noise Margin 31
Attenuation(dB) 13
Message 7 of 8
(536 Views)
14-04-2011 12:11 PM
HI darran,
Your profile is now 12000 so you should be seeing much better speeds now.
Jojo
Jojo
Message 8 of 8
(536 Views)
