What is the difference between LLU and ASDL2+
- What is the difference between LLU and ASDL2+
04-02-2011 10:04 PM
Could someone please tell me what LLU and ASDL2+ mean? Which one is best? What are the pro/cons of both? I think I am on ASDL2+ with Plusnet. thanks
Message 1 of 4
(2,607 Views)
3 REPLIES 3
Re: What is the difference between LLU and ASDL2+
04-02-2011 10:19 PM
Basically LLU is where the ISP has its own equipment inside the exchange, but they still use the same wire from the exchange to the home, they are not reliant on the Horrible BT line speed contol.
For a look inside the exchange look at this extensive overview and explanation http://www.kitz.co.uk/adsl/telephone_exchange.htm
Message 2 of 4
(755 Views)
04-02-2011 10:21 PM
LLU = toll road. ADSL2+ = Ferrari.
So, "What is the difference between LLU and ASDL2+" is a a pretty meaningless question now you know.
(like comparing apples with wind speed?)
Message 3 of 4
(755 Views)
05-02-2011 12:20 AM
Not quite accurate
LLU = toll road, no speed restrictions
ADSL2+ = Ferrari, jaguar, vauxhall, mini, pushbike, unicycle (depending in how well the DLM works)
Both use the same technology to supply the connection, the main difference is with LLU where the ISP has their own equipment and does not use DLM (dynamic line management - the curse of BT ADSL!) to control the connection.
The sync speeds between the two are comparable, the data rates usually are not (LLU is far superior), especially when ADSL2+ is crippled by BT's DLM..
LLU is usually a cheaper option as the ISP can control the costs more.
Message 4 of 4
(755 Views)
