What happened to my speed?
samb
Hello,
I just did a quick speedtest and I am showing on 12mbps.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: What happened to my speed?
Sorry about that, it looks as though your speed profile is set incorrectly.
Can you restart your router and run a further Speed Test and see if that resolves the issue please?
Chris Pettitt
Cloud Environments Engineer
samb
Hello,
Yes it looks fine now. Can you check and see why that happened?
Sam
Plusnet Staff
Plusnet Staff
Fixes: 5
Nothing has changed on your line that I can see. Your speeds are synced at the maximum 80/20 and your Speed Profile hasn't budged.
Is there a chance it could have been something internal?
Chris Pettitt
samb
Hello,
Like what? certainly the OR modem or router has not been unplugged or rebooted recently (not been touched). So what else could have caused it?
Sam
jim:quote
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi Sam,
It could have been a large number of things that caused the temporary blip. It could have been something external such as road works/gas works or something similar that caused interference on your line for a short time. I wouldn't think it's anything to worry about unless it starts to happen on a regular basis.
Chris Pettitt
