What happened to my speed?
- Re: What happened to my speed?
15-06-2010 9:07 AM
Here is what I have done to check my end:
Tested various download locations that always give good speeds.
Rebooted my rooter.
Rolled back my PC to a period before the issue occurred.
Checked (using inSSIDer) to see that there aren't any new wi-fi networks interfering, in fact the issue exists even when no nearby networks are broadcasting.
My router readings seem the same as ever, and are as follows:
The BT speedtest results are as follows:
To me it definitely looks like I am being throttled as plusnet, what do you think?
15-06-2010 9:16 AM
http://www.mybroadbandspeed.co.uk/
http://www.thinkbroadband.com/speedtest.html They also have some test files of various sizes you can time downloading using your normal browser/download software: http://www.thinkbroadband.com/download/
http://www.bbc.co.uk/iplayer/diagnostics
15-06-2010 9:18 AM
Sorry - I just couldn't resist
15-06-2010 9:23 AM
@Jelv: I will check them out and report back.
15-06-2010 9:25 AM
Quote If you don't know why should you think that anyone else would?
15-06-2010 9:56 AM
15-06-2010 10:02 AM
15-06-2010 10:12 AM
BBC iPlayer downloads last night after midnight. Usually an hour program (600+mb) comes down in 10/15 minutes. last night it was showing 1h45m.
15-06-2010 10:22 AM
15-06-2010 10:26 AM
Any support staff care to hazard a guess at what is happening?
15-06-2010 10:43 AM
15-06-2010 10:47 AM
15-06-2010 10:50 AM
Quote from: jelv Three times dialup? Have you got your units right? I'm guessing the download is being shown in KBps - dialup modem max's at 7KBps.
All I can tell you is it is slower than a dead squirrel whereas it used to be like a one on pills zipping from branch to branch.
James, Mand are you there? Can somneopne look at this please?
15-06-2010 11:05 AM
Have you tried changing gateways?
Are the speeds poor all the time? Or is it just today you've seen the issue?
15-06-2010 11:09 AM
A couple of days now, can you point me at how to change gateways and suggest which one?
