What garbage speed on FTTC
thesawdust
So, i've just done a speed test because i've a ticket open regarding faults (Which hasn't be answered to either)
BTW Speed test has the following:
Download speedachieved during the test was - 17.65 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-46.49 Mbps .
Additional Information:
IP Profile for your line is - 46.49 Mbps
Upload speed achieved during the test was - 0.39Mbps
I'm getting tired of this garbage now, PlusNET don't reply for 24hours + and my FTTC runs like ADSL2? I can't take time off work for BTOR to visit *again*
Re: What garbage speed on FTTC
Ouch ! (still 3 x the speed of my old ADSL though !)
Is that tested using a wired connection or wireless ? You may have been asked this before if you've posted on here about it but its one of the biggest issues people seem to have.
Often I'll struggle to get over 20Mb up/down on my wireless while other times I can manage around 40Mb/18Mb. On a wired connection I get a consistent 65-67Mb connection.
thesawdust
Was on wired  Roll eyes
I'm more annoyed the portal said they answered my faults? Well i guess they never  Angry
I also found that in my early FTTC days, my speed slowed down down after a while to a crawl, by logging on to the router, doing a disconnect, waiting 30 seconds and reconnecting I got my full speed back. After a couple of months this seemed to sort itself out.
Maybe absolutely nothing to do with your issue but you never know.
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi thesawdust,
Could you try connecting via PPPoE ( http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows... ) and let us know if the speeds are the same/similar please?
Chris Pettitt
Cloud Environments Engineer
thesawdust
I'll do this in morning, I've an early start  Cry
Plusnet Staff
Plusnet Staff
Fixes: 5
No worries, if you could give us a quick post once you've done that, I'd happily take a look at your line for you Smiley
Chris Pettitt
I think the upload of 0.39Mbps should be of particular concern, that would be fairly poor for ADSL2, something seriously wrong there.
Unfortunately the BT 'diagnostic' speed test gives no clue regarding upstream sync rate (unlike downstream).
Maybe your upstream has a massive error rate and is retransmitting a lot which could (possibly) limit the downstream if acknowledgements have to keep being re-sent.
Call me 'w23'
