What does this mean???
rena
Would someone please be kind enough to tell me what these stats mean, and is there anything wrong with them?  thanks very much in advance guys.
Fixes: 62
Re: What does this mean???
unfortunately we aren't mind readers  Grin Grin
rena
Sorry Oldjim, forgot to press Paste!  Grin
DSL Connection
Link Information
Uptime: 1 day, 1:01:49
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 23,336 / 8,476
Bandwidth (Up/Down) [kbps/kbps]: 445 / 6,656
Data Transferred (Sent/Received) [MB/GB]: 214.84 / 1.16
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 15.5 / 28.5
SN Margin (Up/Down) [dB]: 31.0 / 6.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 36 / 0
Loss of Signal (Local/Remote): 327,679 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 458,752 / 0
FEC Errors (Up/Down): 56 / 4,107,570
CRC Errors (Up/Down): 13,996 / 1,094
HEC Errors (Up/Down): 16 / NA
Fixes: 62
The results are a lot worse than they should be for your attenuation - downstream speed should be much higher on ADSL2+
The worrying bit is the very high number of error seconds in just over a day.
Can you try the test socket and report back
jojopillo
6656k looks like it's banded to me. I'll have to wait until Monday before I can do anything about that.
Jojo Smiley
Fixes: 62
How can it be banded with a 6.5dB noise margin
jojopillo
Hi rena,
Just ran a line check and sure enough, it's banded, as I suspected. I'll have to do some more investigating to see what's going on. I'll get back to you.
Jojo Smiley
rena
What does 'banded' mean?
jojopillo
Hi rena,
There's a little bit of an explanation here about banded profiles.
Jojo Smiley
jojopillo
HI rena,
I've lifted the banding now so you should see the sync rate is up but I'll have to check the IP profile in a bit to see when that goes up so I can make changes on your account.
Jojo Smiley
Fixes: 62
Why do you expect the sync rate to rise when the noise margin was 6.5dB
jojopillo
Because the sync rate was restricted by the banding.
Fixes: 62
So now the sync rate will be restricted by the default noise margin of 6dB - with, I would have expected, very little difference. See my earlier post where I flagged up major problems with the line
Quote from: Oldjim
jojopillo
Hi Jim,
The sync rate is now 6936 with SNR of 9dB.
Jojo Smiley
Fixes: 62
[Censored]  Embarrassed Embarrassed
If that is on ADSL2+ then there is still a problem
