What do you make of these stats?
- What do you make of these stats?
19-03-2011 1:42 PM
These incidents seem to happen randomly, approximately every couple of days, but I can't seem to find a pattern. It doesn't seem to coincide with central heating, incoming phone calls etc. I should be getting a much faster speed, but these disconnections followed by short periods of low margin are keeping my profile at 2000. All day today the router has been synced at 5408 with a noise margin of 7.5dB and seems to be perfectly stable, but in a couple of days, this is going to happen again...
Any idea what could be happening?
Re: What do you make of these stats?
20-03-2011 12:01 AM
Does the plot of bitswaps vs time (from RouterStats) show significantly different behaviour during the periods free of noise and in the presence of noise? Usually there is considerably more bitswap activity after dark (15-30 swaps per minute on my connection) than during daytime (0-3 swaps per minute).
20-03-2011 1:34 PM
However...
I tried another speed test last night, and for the first time since switching to PlusNet on the 5th of February, my speed is back to 4Mb! It seems that at some point yesterday my profile finally increased from 2000 to 4500. There's always the chance that another of these wierd noise events will occur and knock it back down, but I'm keeping my fingers crossed since I found this:
Quote Planned RADIUS server maintenance - Wednesday 16th March 2.00pm-3.00pm
15/03/2011 @ 14:39
When's this work happening?
Tomorrow afternoon, Wednesday 16th March.
What does it affect?
Broadband Connectivity.
How long will it take?
About fifteen minutes.
What does the work involve?
We're moving a number of customers from our 'IP Stream' broadband network to our 'IP Stream Connect' broadband network.
Am I likely to notice the work?
It's unlikely but you might. Broadband customers with connection usernames that end '@plusdsl.net' will be moved across to the alternative network the next time they disconnect/reconnect. Whilst this won't have any noticeable impact on the performance of customers' connections, some of the more observant/technically minded may notice it.
Is there anything else I need to know?
Further detail about these changes can be found in the blog post here - http://community.plus.net/blog/2010/12/17/new-plusnet-broadband-network/
Kind Regards,
Matt Taylor
Customer Support
The date doesn't quite correspond, but I am one of those '@plusdsl.net' customers. It'll be interesting to see if PlusNet have fixed my problem by doing this. In the meantime, I'm delighted to be able to watch iPlayer in HD again!
20-03-2011 6:39 PM
I'm just going to leave my support ticket open for now (it's currently on hold until I get switched to 21CN at the end of the month) but if anyone has any insight into what might be happening I'd be interested to hear it.
I enjoyed getting my old speed back for a few hours there!
20-03-2011 8:32 PM
Unfortunately these plots only identify the nature of the problem, they don't show the cause. It's a moot point whether it will follow you to ADSL2+.
21-03-2011 9:31 PM
Quote from: spraxyt I expect the bits per tone plot looks different between the times with a higher sync and those when sync speed is lower.
Looks like you're right. For the hell of it, here are two charts. BitswapsTonesGood.jpg is from when my noise margin was 17dB and BitswapsTonesBad.jpg is from after it had suddenly dropped to 6.5dB.
I've also noticed the bitswaps/time graph shows a large spike not just when the noise margin suddingly drops but also when it suddenly increases again. It's just shot up to 17.5dB after spending a couple of hours at 7dB and there was a big bitswaps spike at the time. When the margin is steady tt seems to show almost no bitswaps when the noise margin is around 6-7dB and more when the margin is around 17-18dB.
Again, I don't pretend to understand what any of this means!
22-03-2011 12:13 AM
22-03-2011 8:51 PM
23-03-2011 12:18 AM
From these pictures I doubt that ADSL2 will improve things at bad times, possible small effect because minimum acceptable bits per tone is 1 on ADSL2 whereas it is 2 on ADSL1.
So we can see the effect of the problem, but unfortunately this doesn't identify the cause. Since it's a night-time effect it could be lighting - does it begin when the street lights, or security lighting comes on? You don't live across the road from an electrical substation?
23-03-2011 6:20 PM
It happens during the day as well. Timing of the events seems random. That's why I'm using RouterStats, to see if I can find a pattern, but if there is one it's eluded me so far. There are no electrical substations near me and I can't think of anything environmental that could be causing it. To be honest, I'm still inclined to think it's a PlusNet issue as it started as soon as I switched to them after years of no similar problems, but they can't find anything wrong at their end.
I'll see what happens after I'm switched to 21CN (which should be soon), but I'm now doubting it will make a difference. If it doesn't I now have plenty of logs and graphs I can share!
23-03-2011 11:53 PM
