What do you do if connecting to the test socket works?
- What do you do if connecting to the test socket wo...
Re: What do you do if connecting to the test socket works?
14-07-2012 8:04 AM
I read a suggestion that maybe you should disconnect the ring wire at all the extension sockets also but these are polished chrome screwless types and I don't know how to get inside them.
14-07-2012 9:04 AM
Quote from: Routefinder It is not suitable for use with Virgin Media Fibre Broadband or any ADSL 2/2+ service.
Only the first part of that statement is likely to be correct.
It's perfectly suitable for and works very well with ADSL2+
14-07-2012 10:45 AM
14-07-2012 11:35 AM
It's quite a clever design in fact.
You can obviously install it without disconnecting any extension wiring. Just slide it in like the original iPlate.
It supplies an RJ11 socket effectively straight from the Test Socket and then isolates and filters the extension wiring (which obviously cannot then carry ADSL).
There are also some terminals so that you can run your own unfiltered extension if you do need the modem somewhere else.
14-07-2012 4:28 PM
Quote from: HPsauce
It also says: "connection of the Fibre Broadband VDSL modem to the FTTC Broadband is provided by the shuttered RJ45 socket on the front (top section) of the unit" - it's not an RJ45 socket, it's an RJ11 socket.
14-07-2012 4:37 PM
14-07-2012 8:46 PM
14-07-2012 8:52 PM
Quote from: ReedRichards I completely disconnected the ring wire at the master socket but it has not made any difference: 2000 kbps in test socket, 650 kbs in master socket.
Either the cable going to the extension sockets is not CW1308, or there is a fault on it, poor quality filters are being used or something plugged in without a filter (eg. a sky box).
14-07-2012 9:13 PM
Quote from: Anotherone is that 2 IDC terminals top LH, if so what are they connected to?
RTFM, or even this thread
(they're for what I stated earlier - adding an unfiltered extension if you want the modem elsewhere)
14-07-2012 9:28 PM
Quote from: Anotherone Either the cable going to the extension sockets is not CW1308, or there is a fault on it,
Nothing I could do about either of those
Quote from: Anotherone ... poor quality filters are being used or something plugged in without a filter (eg. a sky box).
This happens whether or not there is anything plugged in to the extension sockets, or at least I unplugged everything my clients remember is plugged in - I always ask about a Sky box as they seem to be so frequently overlooked.
14-07-2012 9:32 PM
Quote from: HPsauce (they're for what I stated earlier - adding an unfiltered extension if you want the modem elsewhere)
Woops, my apologies I missed that
And is the bell-wire still fed through to the front plate?
14-07-2012 9:51 PM
If you don't need the bell WIRE running to the extensions then don't connect it on the front plate. Most modern handsets don't need or use it.
14-07-2012 11:30 PM
15-07-2012 10:11 AM
Quote from: Anotherone Non-techie users could be under the impression that this is a super i-plate with a built in filter
(and RJ11 modem socket)
My belief is exactly that, though it would need someone to read the specs to confirm for certain.
31-08-2012 5:36 PM
Quote from: HPsauce The new-style "VDSL" interstitial plate is pretty good. I have one now and it works a treat on ADSL2+.
Here for example: http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=13095
I just fitted one of these and it really does work a treat. Sync rate went from ~700kbps to ~4500kbps with the extension wiring connected.
My grateful thanks to HPsauce for drawing my attention to these plates.
