What are a normal number of errors, crc, hec ?
- Re: What are a normal number of errors, crc, hec ?
25-05-2014 5:02 PM
I was wondering what a normal number of errors would be? I have what seems like quite a lot over a relatively short time.
Is there a guide number?
Line state: Connected
Connection time: 1 day, 20:55:10
Downstream: 8,064 Kbps
Upstream: 448 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 11.1 dB / 28.0 dB
Line attenuation (Down/Up): 37.0 dB / 22.0 dB
Output power (Down/Up): 20.0 dBm / 12.4 dBm
FEC Events (Down/Up): 658088 / 344
CRC Events (Down/Up): 10809 / 138
Loss of Link (Remote): 0
HEC Errors (Down/Up): 1084065 / 221
Hide Details
Message 1 of 6
(4,505 Views)
5 REPLIES 5
25-05-2014 5:44 PM
it all rather depends - good answer NOT
Take my case
The errors are horrendous but not a problem
After 10 days
Errors:
FEC: 7190939
CRC: 31874
HEC: 312534
This graph shows that the problems occurred during two daylight periods as shown
The reason was that there were thunderstorms rolling about in the distance
Note specially that there are no error secs in your case so there really isn't a problem
Basically if the line is stable and you aren't seeing any problems with browsing you can ignore them
Take my case
After 10 days
Errors:
FEC: 7190939
CRC: 31874
HEC: 312534
Message 2 of 6
(4,075 Views)
25-05-2014 5:53 PM
However - given the high noise margin I am surprised that they are as high as they are so a bit of investigating would be useful for the the time when your exchange upgrades to 21CN
Can you connect the router to the test socket behind the master socket removable lower half (the link I gave above explains it) and leave it there for a couple of days and then report back
Message 3 of 6
(4,075 Views)
25-05-2014 6:09 PM
By definition, an errored second is a second that had one or more CRC errors (amongst other things). So there can't have been zero errored seconds and 10809 CRC errors. Probably the errored seconds count just never gets updated and will always display as zero. I know my router will always show zero errored seconds when using ADSL1, but shows correct errored seconds counts on ADSL2.
Message 4 of 6
(4,075 Views)
25-05-2014 6:50 PM
Thanks. I currently am plugged in to a new mk2 bt faceplate that contains the filter so would need to figure out how to take that apart!
I might just leave it and keep an eye on it for now. Connection working ok at present, although the connection time is usually not longer than 3 days. But I have a ticket ongoing with support at present trying to figure out what might be wrong.
Message 5 of 6
(4,075 Views)
26-05-2014 3:37 PM
I found some related figures in a BTWholesale PDF called Slow Throughput Best Practice Guide
According to that, the mean time between errors should be at least 50 seconds, and the number of errored seconds should be less than 20 over 15 minutes.
Message 6 of 6
(4,075 Views)
