What IP address ranges does PlusNet use?
- Re: What IP address ranges does PlusNet use?
25-01-2011 11:08 AM
I'm using PlusNet Value broadband and I've been asked what IP address ranges I'm likely to be using, so that my account can be allowed on a particular server which limits who can access it and from where.
I have looked up my current address and www.ripe.net tells me this is part of the block 87.112.0.0 - 87.115.255.255. That's a good start. Are there other address ranges I might be using, perhaps tomorrow if I'm disconnected and connected again?
Yes, I know I could upgrade to a more expensive service and ask for a static IP address. But I hope not to need to do that.
Message 1 of 4
(7,185 Views)
3 REPLIES 3
25-01-2011 11:14 AM
Quote from: mhi I'm using PlusNet Value broadband and I've been asked what IP address ranges I'm likely to be using, so that my account can be allowed on a particular server which limits who can access it and from where.
I would say it's not much of a limit when they do it by block.
Message 2 of 4
(3,232 Views)
25-01-2011 11:17 AM
Quote from: mhi Are there other address ranges I might be using, perhaps tomorrow if I'm disconnected and connected again?
See here.
Message 3 of 4
(3,232 Views)
25-01-2011 11:28 AM
@Bob - thank you very much. I did try to search this forum for a post similar to that one, honest, but I didn't try very hard.
@itsme - I didn't set this server's policies. The server can, though, now define "mhi + password accepted only from PlusNet broadband" rather than "mhi + password accepted from anywhere" (or, as it is so far, "mhi not accepted at all"). That cramps the style slightly for a scammer wanting to use the same server.
Message 4 of 4
(3,232 Views)
