What ADSL Routers are best with Plusnet
- What ADSL Routers are best with Plusnet
18-11-2009 11:36 AM
I've got an old ADSL Router (is capable of doing adsl2+). I've been getting intermittent synch issues that are ruining my new adsl2+ speeds. After many days of getting plusnet to do tests..they came back saying "line is fine...if you want BT out, you could face a hefty bill if no fault etc etc".
My router is a Linksys WAG354G V1 (running firmware 1.00.11 or something dated dec-2006) and I've read reports and posts from all over the place about people having synch issues with various routers (using AR7) chipsets etc.
Unfortunately having a noisy line It may be that the linksys isnt very good at dealing with that...
Anyone had similar problems that were solved by upgrading the router to a different brand?? if so what you using?
Re: What ADSL Routers are best with Plusnet
18-11-2009 2:03 PM
18-11-2009 2:11 PM
18-11-2009 2:15 PM
18-11-2009 3:19 PM
I do actually have the current firmware installed though (its an old product though so its about 3 years since any updates)...didnt make a great deal of difference..
Suspect my noisy line is rather responsible...thus the opinions on good ADSL routers...I've read some are better than others at dealing with crap line conditions...seems the WAG354G (which was fine for maxdsl) isnt one to deal with them so well..
18-11-2009 3:28 PM
ive spent many months stuck at sync of 3072 due to DLM banding me, its only past month ive been happy with my 21cn connection
alot of history of my line here since going on 21cn http://community.plus.net/forum/index.php/topic,75667.0.html all on my dg834g v4 apart from a few days on a belkin but i was banded when i tried that so couldnt get an idea how it coped sync wise
worth noting thoe that the v4 has a broadcom chip where the new v5 dosent
18-11-2009 4:50 PM
Some would recommend Billion, though I don't have any experience and a lot on these forums would recommend the DG834G v4 or GT. Don't get the DG834PN whatever you do.
18-11-2009 5:36 PM
Quote You could try and get something like an unlocked 2700HGV on ebay, they are pretty good on long lines from my experience - you would need an unlocked one though.
I wish people wouldn't keep letting the secret out about these 2700's, there'll be none left when I need another spare
Adie, they're all usable on PlusNet ( and most ISP's ) with a little persuasion, even the latest V6 ones...
18-11-2009 9:28 PM
19-11-2009 11:17 AM
Quote from: MisterW I wish people wouldn't keep letting the secret out about these 2700's, there'll be none left when I need another spare
Loved mine... until the wireless failed on it
