Weird tracert result ?
deathtrap
Target Name: pingbox1.thinkbroadband.com
        IP: 80.249.99.164
 Date/Time: 09/05/2014 08:11:30 to 09/05/2014 08:38:27
Hop Sent Err  PL% Min Max Avg  Host Name / [IP]
1  1000   0  0.0   1   0   0  home.gateway.home.gateway [192.168.1.254]
2  1000   0  0.0  13  42  14  138.core.plus.net [195.166.130.138]
3  1000   0  0.0  13 100  15  link9-central10.pcl-ag03.plus.net [84.93.249.81]
4  1000   0  0.0  13  91  15  ae1.ptw-cr01.plus.net [195.166.129.0]
5  1000   0  0.0  14 232  18  linx-gw1.thn.ncuk.net [195.66.224.240]
6  1000   0  0.0  14 212  16  te2-1-9.star10g.bdr-rt3.thdo.ncuk.net [80.249.97.17]
7  1000   0  0.0  14 106  16  te1-1-1-31.core-rs2.thdo.ncuk.net [80.249.97.85]
8  1000   0  0.0  14  16  14  pingbox1.thinkbroadband.com [80.249.99.164]
Shouldn't  the host name of  the IP on hop 2 be PCL 03 ?  because that's  the Gateway that the Plusnet  Gateway checker tool is reporting  I'm connected to ?
Fixes: 76
Re: Weird tracert result ?
No Hop 3 is where it shows the hostname for PCL 03 so I'd not expect to see that info against any of the other hops listed.
 Adam Walker
deathtrap
Interesting, but still weird when you compare this tracert
        IP: 80.249.99.164
  Date/Time: 09/05/2014 13:14:06 to 09/05/2014 14:00:46
1  1000  0  0.0  0  0  0  home.gateway.home.gateway [192.168.1.254]
2  1000  0  0.0  12 382  20  lo0-central10.ptw-ag01.plus.net [195.166.128.195]
3  1000  0  0.0  12  70  13  link-a-central10.ptw-gw01.plus.net [212.159.2.144]
4  1000  0  0.0  12  66  13  xe-4-2-0.ptw-cr01.plus.net [212.159.0.240]
5  1000  0  0.0  12 216  16  linx-gw1.thn.ncuk.net [195.66.224.240]
6  1000  0  0.0  12 187  14  te2-1-9.star10g.bdr-rt3.thdo.ncuk.net [80.249.97.17]
7  1000  0  0.0  13  69  14  te1-1-1-31.core-rs2.thdo.ncuk.net [80.249.97.85]
8  1000  0  0.0  12  14  12  pingbox1.thinkbroadband.com [80.249.99.164]
The PTN gateway is the 1st hop after my router, But on the first tracert  it doesn't display the gateway's host name on the 2nd hop
Plusnet Alumni (retired) paulmh5
Hi
You are on a new BNG, the DNS is being updated today or Monday hopefully.
Plusnet Staff - Lead Network Design/Delivery Engineer
Fixes: 10
Quote from: _Adam_Walker_
When did this change Adam? It always used to be hop 2 - and still is on my tracert.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 165
It is hop 2 if you're not on the BNG gateways, as Paul says the DNS for them is being updated asap.
 Chris Parr
 Plusnet Staff
deathtrap
But, when i used the plusnet gateway check tool, it reported that i was connected to plusnet gateway PCL03 , Hence why i said i thought it was unusual /weird
Fixes: 21
The gateway is the first hop after your own router, regardless of the accuracy of the reverse DNS entry.
The reverse DNS for 195.166.130.138 is now lo0.10.central10.pcl-bng01.plus.net.
Fixes: 10
Perhaps you'd like to edit your post Adam as it's duff information!
Fixes: 10
Quote from: ejs
I'd like to see a tracert from someone on that gateway. Also is the Plusnet Gateway checker tool reporting the correct name now?
deathtrap
@Jelv i have hopped gateways  some time ago , so i can't say what i currently is reporting by the gateway checker, are the BNG gateways  reported by that yet  ?
Fixes: 21
The reverse dns for 84.93.249.81 was also out of date, it is now irb.10.pcl-cr01.plus.net.
