Webstats and Safari?
- Webstats and Safari?
18-12-2007 9:59 AM
Am I the only one who cannot view the PN webstats using Safari on a Macintosh (OS X 10.5.1)?
I don't get the login pane when the window for webstats opens. Have had to use Firefox as a temporary workaround.
Message 1 of 5
(1,068 Views)
4 REPLIES 4
Re: Webstats and Safari?
18-12-2007 10:36 AM
Hmm, interesting. I can view them fine (using the same setup as you), but I saved the password information to my keychain back in the Tiger days so I'm not actually asked to type in my password - I'm just taken straight to the stats. If you want to try this yourself, you could use the Keychain Access utility to manually create an entry (assuming Firefox doesn't save passwords to the Keychain - maybe it does, I can't remember) then try in Safari.
Message 2 of 5
(434 Views)
18-12-2007 11:03 AM
Works OK using Safari in Windows (which doesn't tell us much but I thought I'd mention it none-the-less!)
Message 3 of 5
(434 Views)
18-12-2007 12:11 PM
Tis very odd, I tried putting an entry in Keychain but that still does not fix it. Have cleared the cache in Safari also.
Message 4 of 5
(434 Views)
18-12-2007 12:14 PM
Fixed it!
Deleted all existing keychain entries to do with portal.plus.net.
Message 5 of 5
(434 Views)
