Website seems to be blocked/inaccessible via PlusNet
- Website seems to be blocked/inaccessible via PlusN...
- « Previous
- 1
- 2
- Next »
Re: Website seems to be blocked/inaccessible via PlusNet
04-06-2024 10:32 AM - edited 04-06-2024 10:34 AM
I noticed this yesterday and reported it to my employer, which happens to be Fastly.
Our NOC team has contacted the BT and Plusnet respective teams with their findings, asking them to investigate.
This seems to be more widespread, and the affected IP addresses and their covering subnets are as follows:
- 185.199.108.153 (185.199.108.0/24)
- 185.199.109.153 (185.199.109.0/24)
- 185.199.110.153 (185.199.110.0/24)
- 185.199.111.153 (185.199.111.0/24)
I've also called support this morning, but they said they could do nothing (?).
Hopefully, the network teams will figure it out and correct the issue asap.
04-06-2024 10:35 AM
04-06-2024 11:38 AM
Yep, also working for me now too
04-06-2024 12:13 PM
Back up for me, and also on EE, which was having the same problem. Looks like somebody was hosting malware on a Github Pages site, which meant that Spamhaus.org flagged that block of IP addresses as suspicious. Which meant that BT's network started blocking traffic to any website hosted on any of those addresses.
https://community.bt.com/t5/BT-Fibre-broadband/DNS-Issues/td-p/2387163
https://community.ee.co.uk/t5/Broadband-Landline/Unable-to-access-certain-websites/m-p/1393178/emcs_...
https://github.com/orgs/community/discussions/127187
As of 12:09 on June 4th those addresses (185.199.108.153, 185.199.109.153, 185.199.110.153, 185.199.111.153) still show up in Spamhaus' block list so I'm guessing BT have done something to make sure those addresses don't get filtered.
https://check.spamhaus.org/sbl/listings/fastly.com/
FWIW, when I spoke to Plusnet support this morning, I told them it appeared to be an upstream issue at BT and they just flat out told me there was no escalation path for this kind of incident and that I should use a VPN until it got fixed, which wasn't terribly reassuring.
04-06-2024 12:58 PM
Same.
The fact that BT applies these blocks blindly is mind-boggling.
> FWIW, when I spoke to Plusnet support this morning, I told them it appeared to be an upstream issue at BT and they just flat out told me there was no escalation path for this kind of incident.
I got the same response (minus the VPN part). I understand where the support folks are coming from, but this is not acceptable.
There should be a way to raise this internally.
- « Previous
- 1
- 2
- Next »
